Will this fit under a short valve cover??
Old Aug 25, 2004 | 09:40 PM
ljnowell's Avatar
I have been having a problem with one of my rockers backing off on me. Since I dont want to adjust it every couple of days, I decided to get some of the ARP poly-locks to replace the regular rocker nuts. Does anyone here know if they will fit under short style valve covers? I am running 1.5 steel roller tip rockers, does anyone else run anything similar to this (ARP nuts, roller rockers, etc)? I just want to make sure that if I need new valve covers I order them all at once to save the extra 8 dollar handling fee.
edit:
BTW, here is a link to what I am talking about.
http://store.summitracing.com/defaul...+400295+304700
Old Aug 25, 2004 | 09:53 PM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
I have similar locks I believe the brand name of mine was "kool nuts" I don't think they will fit under "short" covers
Old Aug 25, 2004 | 09:56 PM
ljnowell's Avatar
sweet pic man. I was afraid of that. One of the guys at my local autozone said he knew they would, but I dont take the guys up there very seriously. Kinda sucks if I have to replace them, I guess I will just have a nice set of short chrome valve covers for my garage wall now.
Old Aug 25, 2004 | 11:12 PM
flrtin1's Avatar
Engine: S/B
lol, just like the ones I got hanging on the wall!
Old Aug 25, 2004 | 11:18 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
And then the girlfriend/wife/significant other finds them, flips them over, plants some flowers in them, and puts it on the back deck....like mine did.
Old Aug 26, 2004 | 06:05 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Poly-Locks are ALOT of trouble to go to, if you don't need them. And worse yet, if you're not used to them, they WILL loosen and fall off, at least a couple of times, before you get the hang of it.
For your situation, try double-nutting the nuts you've already got... just add a jam nut to each of them. That's what I usually do for that.
Don't outsmart yourself.
Old Aug 26, 2004 | 08:20 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
im running ARP polylocks on pro magnum rockers.... and it clears both stock centerbolt, and short perim valve covers...
but i have dart heads, and i dont know if they raised the cover rail..
Old Aug 26, 2004 | 10:31 AM
flrtin1's Avatar
Engine: S/B
I don't see how these are that hard to figure out or use, once you set the preload with the outer nut then tighten down the the set screw unless you have other problems they never move. I have used them for over 10 years and they have never come loose!
Old Aug 26, 2004 | 10:55 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
they come loose if you do it that way.
well, if you run a solid roller and do it that way.
think about this:
as you tighten that set screw, its pushing on the stud... and pulling UP on the outer nut. increasing your lash.
if you put the nut where you want it, then back it off about a 1/4 of a turn, then tighten the set screw, then turn the setscrew AND nut back a little over a 1/4 of a turn (to make up for the fact that the screw pulls the nut up) you get a accurately set lash that NEVER moves.
Old Aug 26, 2004 | 11:07 AM
flrtin1's Avatar
Engine: S/B
I see your point with the solid cam (good tip for future use if I don't forget it lol) I have a hydraulic set up and always do my final adjustment with the engine running so that last little bit of movement isn't that critical.
But as far as them loosening up once the set screw is tight I have never had a problem with that.
Old Aug 26, 2004 | 11:30 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
mine fit fine under my short valve covers
Old Aug 26, 2004 | 11:53 AM
flrtin1's Avatar
Engine: S/B
Mine being from crane and in full rollers may be taller
Old Aug 26, 2004 | 01:14 PM
ljnowell's Avatar
RB, I thought about double nutting them, but there isnt enough threads on the top of the stud to fit a second nut. I figured the lockign nuts were the way to go.
MoJoe
Sep 24, 2015 09:12 PM
NBrehm
Aug 25, 2015 11:49 PM
g.l.mos
Aug 22, 2015 12:02 AM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
