Highest NA higpower//torque thirdgen?
Old Aug 28, 2004 | 12:09 PM
Farfire70's Avatar
I'm just looking around at everyone's information on horsepower and torque and I got interested in who is putting out the most in a third gen. I don't want to see a blower or turbo though. Just highpower engines. If you've seen a high power third gen but it's not yours post it and we'll see if we can find out whose it is. Also, give a list of all you've done.
Old Aug 28, 2004 | 12:48 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Well, I don't have any RWHP numbers. Just engine dyno, Tq is the stongpoint. I know that there are others here that are more impressive!
In sig.
Old Aug 28, 2004 | 03:49 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
I bet this one is in the running...
Old Aug 28, 2004 | 05:22 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Hehe full race bb vs a streetable sb. Thats a tough choise.
Old Aug 28, 2004 | 09:11 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Do a search for Baddest 305....he runs 10s NA with a "big" small block.
Old Aug 28, 2004 | 10:14 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Might want to define streetable for arguements sake.
Isn't there that 1600 or so horse twin turbo camaro somewhere?
Old Aug 28, 2004 | 10:57 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
he said n/a so no turbo
Old Aug 29, 2004 | 03:36 AM
SchwarzCamaroRS's Avatar
i always wondered if it was possible to make 1000hp out of an n/a sbc... ive heard of 600hp+ on 400+ cid sbc's... the engine buildoff thing from hotrod magazine i think it was had master engine builders getting almost 700hp from sbc's
Old Aug 29, 2004 | 04:42 AM
Rembrandt's Avatar
1000hp, depends on cubic inches.
500 cid prostocks rev to about 9000 and make about 1300hp.
That is 2.6 hp per cubic inch. They are "maxxed" out, totally unstreetable, short-life race engines.
It would take a 386 cid small block of the same efficiency and revs to make 1000hp.
Keep in mind NHRA pro stock is the ultimate N/A V8, with the world's finest engine builders striving to make that much.
The best N/A 4-strokes car engines in the world make 930hp from 183 cid on pump equivalent gasoline. of course, they rev to 18-19,000 rpm and cost millions of dollars. Formula 1, 5.1 hp/cubic inch.
I think that Joe Sherman, who won the first engine masters challenge, made about 600 hp from a 365 cid Chevy and it was very streetable even though it was only a dyno test.
For 66.6% more horsepower, you would need 66.6% more displacement at the same efficiency, or about 608 cubic inches.
You're looking at an aftermarket casting big block here.
Old Aug 29, 2004 | 07:10 AM
screamin' 85 z's Avatar
Car: 85 IROC
Engine: 355 CI n/a
Transmission: 700 r4 w/3500 Coan
505 HP / 485 TQ
355 ci
trick flow heads
crower solid roller cam, springs, lifters, stud girdle
JE pistons/rings
stock steel crank
Crane roller rockers (1.6 on the intake, 1.5 exhaust)
Victor Jr intake
Holley HP 750 DP
MSD distributor/ignition
Old Aug 29, 2004 | 08:25 AM
ede's Avatar
ede
i was going to say bruce allen would have to be in the top 10. lee shephard died in 84 so allens car would of been ahead in the HP/TQ race
Old Aug 29, 2004 | 09:08 AM
Cameron's Avatar
Car: 1985 Z28
Transmission: 700-R4
car craft had a 740 small block 350 but it ran on 101 octane w/ 14:1 compression
Old Aug 29, 2004 | 01:20 PM
i saw a recent mod for Z06 vettes, i dont remember the name of the guy doing it, but he only did it to 50 vettes. but he put a streetable version of the genIII LS6 engine w/ 427cid and it made almost 600hp w/ stock LS1 heads and cam. if he had some good heads and a nice grind, those motors could put out probably close to 800-900hp
Old Aug 29, 2004 | 03:17 PM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
Transmission: Quickest, quicker, quick...
Axle/Gears: 10 bolt, 3.73
Does my Big Block count? Or can it only be small blocks?
Old Aug 29, 2004 | 05:57 PM
The Doc's Avatar
BADDEST305 is a great guy running a top dollar big inch crate SBC from Shafiroff crate. Check their site for the numbers but heres a copy of his sig:-
1.44-60ft.
6.58-1/8@ 104.4
10.34-1/4
130.1- mph
scott shafiroff build 434--12:1 comp, motown block, comp cam 254 dur. 594 lift,, callies crank, afr227 heads, dart intake, lunati rods, king demon 1095 carb, msd ignition, stahl 2" jet hot headers, th350, CSI scattershield,ATI 5000stall,moser 9" 4:11's w/spool,35 spline, PA tubular k-member, wolfe racecraft rear sway bar, wolfe racecraft adj. panhard bar,90/10 drag struts, 50/50 drag shocks, adjustable lca, lca relocation brackets, 6 pt., 28" phoenix slicks ALL MOTOR
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
gwade12
Aug 8, 2015 08:17 AM
