MAF sensor, can you run without it?
Old Aug 30, 2004 | 05:41 PM
89IROCZTPI's Avatar
Car: 1989 IROCZ
Engine: Rebuilt 350 TPI
what would happen if I ran my car without a MAF sensor?
Did a search and found nothing that could really answer my question.
Old Aug 30, 2004 | 06:25 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Why in the world would you want to?!? It's stupid. You'd run really rich (IIRC safety mode is rich) and really crappy as compared to a correctly tuned motor. Probably ruin the O2 and EGR off the top of my head.
sellmanb's Avatar
Car: '86 Berlinetta
I'm no expert but no MAF would probably be the exact same as a faulty MAF that didnt work lol.... I'm assuming that you could, but it would make it run speed-density ( I believe?). Again, I'm no expert... I dont even have a TPI engine lol... why dont you go give it a try? heh.
Old Aug 30, 2004 | 06:34 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Wow, I can convert my MAF car to a speed density just by unplugging my MAF? Holy crap bat-man. I have got to go over to the Prom board and let them in on that little secret.
Do I get a magically appearing MAP sensor everytime I unplug my MAF?
Old Aug 30, 2004 | 06:46 PM
89IROCZTPI's Avatar
Car: 1989 IROCZ
hehe, thanks for the info, my MAF sensor is bad, and I was wondering if it was a good idea to drive without it connected, but since its not, I wont. Thanks again.
Old Aug 30, 2004 | 06:48 PM
LnealZ28's Avatar
Car: 1987 Z28
Engine: 383 Single Plane EFI-NOW RUNNING!
Axle/Gears: Not there yet...
HERE'S a lengthy discussion, right or wrong............
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
How did you determine it was the sensor as opposed to the relays? (A whole lot of people swap out their MAFs for no reason.)
Old Aug 30, 2004 | 06:52 PM
sellmanb's Avatar
Car: '86 Berlinetta
Heh, sorry Red Devil, I DID say I was un-sure of my information in that post though. Where I got that information was from reading on Camaroz28.com in the LT1 section, i remembered that when their maf fails it falls into speed density mode (like the '93 LT1 is a speed density). Now as to whether THAT information is even correct I do not know... there seems to be a lot of mis-information running around, guess I'm not helping any eh? lol. Sorry man.
Old Aug 30, 2004 | 07:22 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
No worries. I always have fun. This time it happened at your expense. Without research I would doubt the veraciousness of that info.
Old Aug 31, 2004 | 03:25 PM
Damon's Avatar
Yes, the car will run and drive like that. Check engine light will be on solid for obvious reasons. There is no MAP sensor for the ECM to fall back on in TPI engines equipped with a MAF sensor. It just has RPM and TPS and CTS to run the engine.... which ain't much.
YES, doing this CAN be used as a diagnostic test to check for a "flaky" MAF. I've done it several times on different cars. If you unplug it and the car suddenly runs better (or at all) chances are the MAF is bad. This has proven particularly useful when I have encountered engines that start but die immediately after startup. That's classic bad MAF symptoms, although they can fail in other ways.
Another "low buck" MAF test is to idle the engine and lightly tap the MAF with the handle of a screwdriver. If something's loose inside it, or giving an intermittent connection, the idle will immediately stumble or stall outright.
Old Aug 31, 2004 | 03:52 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
I ran for Six months with the Maf disconected (bent pin not making conection) the SES light was on. The car ran good as always (strong) started and idled normal and the gas mileage did not change either. The ECM was making the changes. So to answere the question, yes you can run without the Maf. I have since found the bent pin problem and corrected it (no SES light) and everthing is the same.
Old Aug 31, 2004 | 05:06 PM
89IROCZTPI's Avatar
Car: 1989 IROCZ
never thought of checking anything else honestly, I plug in the MAF sensor and the car stalls out as soon as I start it and it comes to an idle, I unplug it and it starts right up, which makes me think the MAF is bad, I can check the relays, would they be in my Haynes book?
Logan Bryant
Aug 27, 2015 11:52 AM
NBrehm
Aug 25, 2015 11:49 PM
ezobens
Aug 19, 2015 10:29 PM
mdtoren
Aug 16, 2015 05:45 PM
squiggy2
Aug 9, 2015 09:30 PM
