got my car dynoed with/in
Old May 7, 2001 | 03:03 PM
bad camaro RS's Avatar
got my car dynoed at power tour fri i pulled 263.4hp @4800 and 332.1 tq@3600 at rear wheelsive got a 87 355 tpi with edelbrock base and runners afr 195cc heads comucam 2032 1.65 roller rockers 10 to 1 compression whatcha think? i was hoping for 300 rear wheels
1992 camaro RS w/ 350tpi
195cc AFR heads with compition port work milled to 58cc
1 3/4 hooker long tube headers
4" mufflex system
custom ED Wright chip
eddelbroc intake base and runners and much more
new best ET 13.5 @104.66 on stock heads
no times with new afr heads hoping for 12's on motor
http://www.nav.to/badass355tpi
Old May 7, 2001 | 05:11 PM
irocbsa's Avatar
Damn, that is about the same combo I have and I am also hoping for 300 RWHP when I go to the dyno. Hope I'm not dissappointed. Have you gotten any times on the new heads yet??? I was running a 13.5 with the trickflows, stock TPI, and 2.73. Now I have the runners, base, plenum ported, and 3.42 and am also looking for 12s. Let us know how you come out at the track.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old May 7, 2001 | 07:13 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
that does seem a little low. Are these 23lb injectors?
Old May 7, 2001 | 07:54 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Hmm, seems really low to me too. I guess that's LTR TPI for ya though, several others are getting these kinds of numbers with the LTRs...
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Old May 7, 2001 | 09:55 PM
89BlwnRs's Avatar
Since your HP is peaking so low, I would think that your torque is dropping sharply well before 5000 RPM. I'd guess that it might be a lack of airflow, the 190s may be a tad small for a 350 pumping out so much power, plus the Crane Cam may not have the duration it needs to produce power at the higher RPMs.
Just my guessing,
Jason
Old May 7, 2001 | 10:06 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
not bad, about what an LT1 with a couple of bolt on's puts out. but, problem i'm seeing is a cam barely any improvement over an LT1. with them heads, alot more can be had by putting much more cam in it. would be nice to see some numbers if you can get them though from the oxygen sensor under a wot pass. 300hp at the tires is very possible, but that is a rather small cam.
Old May 7, 2001 | 10:21 PM
Ray87Z's Avatar
Car: 94 Z28
Axle/Gears: 3.23s
I don't think you would want to step up the cam much more at all unless you're going w/ a better, shorter runner intake setup. This engine is all low end w/ the long tube runner setup and a cam w/ a lot of duration isn't going to help there...
Ray87Z
-Vortec headed 350.
Formerly Ray86IROC.
[This message has been edited by Ray87Z (edited May 07, 2001).]
Old May 7, 2001 | 10:54 PM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
Hey guys, have you read the hard rock camaro articles in the article section of this site? It made over 330 hp to the wheels and it had long tube runners and the zz-9 cam. BadcamaroRS, even with your runners and cam you should be over 300 rwhp. I'd say your problem is with your fuel delivery to the engine, like maybe bad injectors or something, cause you should defineitely be making more power. That's just my opinion from what I've read on some of these car sites.
Old May 8, 2001 | 05:38 AM
ive got 24# injectors id really like to see what i could get out of the ltr set up but if i knew the mini ram or super ram would take care of this i would get one im jus trying to get all the input before i drop anther $1000+ on the street i win races all the time thats what surprised me when i saw the #s i was running 13.5@104.66 last year with stock heads im bafled
4" mufflex system
1992rs/ss
Jan 31, 2025 05:10 PM
MustangBeater20
Oct 29, 2022 09:20 PM
1984HO
Mar 19, 2021 11:59 AM
Reborn756
Sep 4, 2015 03:42 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
