''performance'' heads on ebay
Old Sep 8, 2004 | 11:23 PM
Dave's 89's Avatar
Car: 89 IROC-Z
Axle/Gears: 4th Gen/3.42
Actually sounds like a great deal, but I've not familiar with the casting #. Anybody have input? My current heads are from a gm goodwrench crate motor. They're marked ''hencho en mexico'' don't have casting #s on hand. Surely these would be a step up from that.... eh? Heres the link.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33617
Old Sep 9, 2004 | 12:15 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
354434.....75-79...262/267/305...60cc chambers
Old Sep 9, 2004 | 01:23 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
IIRC, the 434 heads are fall in the lines of smogger crap. Smaller valves (which are eliminated) and smaller runners.
Old Sep 10, 2004 | 06:27 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
I would finish the job by dissassembling them and completely hand port them. I would either install screwin studs or pin the stock studs. either way works. Other than that they will work well.
These are early 305 heads.
Old Sep 10, 2004 | 07:58 PM
ljnowell's Avatar
ive got the same heads, with some work. They are alright, surely not the best, but they still let the 350 scream. no problems revving past 6k (with usable power too). Are they AFR's? No. Are they the best stock casting, no. But they are ok.
Old Sep 11, 2004 | 05:45 AM
Chris's 85z's Avatar
Car: 85 Z
Engine: 383
That from my local engine shop. Just so you know they do great work. If you call tell Kent you know Chris :~)
Old Sep 11, 2004 | 08:51 AM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Question - it seems that the Intake valve isnt even sitting
inside the bore, looks like its just on top, so you're not getting
maximum efficiency out of those big valves ..
The intake valve is slightly out of the combustion chamber.
Are my observations correct ?
Old Sep 11, 2004 | 06:42 PM
FstBrd6point3's Avatar
I noticed the same thing about that intake valve. Also, the valves are surrounded by so much metal that is you wanted to unshroud them you would probably be right back at a 64cc chamber if not more.
Old Sep 13, 2004 | 07:36 PM
F-BIRD'88's Avatar
its in the pic
Old Sep 13, 2004 | 10:24 PM
Car: 85 Z
Engine: 383
I talked to him today and he said if you want flow number just call and ask he will send them.
Old Sep 13, 2004 | 10:50 PM
laiky's Avatar
i think you would be better off spending the money on a set of stock vortecs or scoggin dickey vortecs or junkyard vortecs or the 900 dollar tfs heads from summit. doesn't make any sense to me to spend 400 bucks on a bad compromise. better off sticking with what you have and upgrading when you can afford it.
Old Sep 14, 2004 | 02:28 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
It is still within the bore. The bore is round while the combustion chamber is often half-circle or wedge shaped.
Here is a pic of my 601s with 1.94" intake valves, which you can see extend well past the combustion chamber but still fall within the bore.
Attached Thumbnails ''performance'' heads on ebay-resize-finished-heads3.jpg
Old Sep 14, 2004 | 07:51 PM
LaxStreetRacer's Avatar
Car: 91 Z28
Rumor has it someplace in Winona has a chassis dyno, Is that by chance the place?? And if so do you know the pricing?
Old Sep 14, 2004 | 08:17 PM
Car: 85 Z
Engine: 383
That would be the place! It is a Mustang Dyno! $60 for 2 runs or $200 for a hole day to tune you ride.
Call and Talk to Kent Tell him Chris sent ya! 507-452-0695
Old Sep 14, 2004 | 10:23 PM
Car: 91 Z28
Thats cool, thanx for the info. I have seen those guys on ebay selling what looked like nicely re-done l98 heads for like 400 as well, maybe if i have them work my heads over I can talk em into a deal on some time before and after to see what kind of changes there were.
Old Sep 15, 2004 | 08:22 AM
Car: 85 Z
Engine: 383
Give him a call he is great to work with! Been working with him for 6 years now never let me down once!
evilstuie
Feb 28, 2016 03:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
87iroctheo
Wheels and Tires
Sep 2, 2015 03:29 AM
