What motor oil do you use?
Old May 3, 2001 | 10:29 AM
TransAm223's Avatar
Is Mobil 1 tri-synthetic one of the best? What grade, 5w or 10w? and how much do you need in a L98, 4 or 5 qu? (don't have manual)
Old May 3, 2001 | 12:16 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I use 5qt's of Mobil 1 15W-50 and a PF-35 Filter in my L98
Old May 3, 2001 | 03:13 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
5 quarts Mobil 1 and a PF-25 filter for my LB9.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, Rapidfire #2 @ .055", MSD 6AL, 1.6:1 Roller tipped rockers, Homemade AFPR, K&N cone, no airbox, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Descreened MAF, Syclone Fuel Pump, JET Airfoil, Mobil 1 synth in all but transmission.
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
Old May 3, 2001 | 04:19 PM
Dan87IROC-Z's Avatar
I use Mobil 1 fully synthetic motor oil 10W30. I would only use recomend using synthetic oil if you have new valve seals. The synthetic oil will drop right down into the chambers if you have bad seals. This will cause you to burn about 2 quarts of oil per 3000 miles. When this oil costs about $4.50 a quart, thats a lot of money you are throwing away.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
Old May 3, 2001 | 04:44 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
My L98 takes 5.5 quarts. I know the spec is 5 quarts, but the spec is the same for all V8's with or without the oil cooler. So I guess the oil cooler holds .5 quarts.
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Old May 3, 2001 | 08:58 PM
F22Raptor's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Dan87IROC-Z:
</font>
You are so right about that. That's exactly what happened to me. Using regular oil now, 20W50, but want to bring viscosity down to 10W30 or so.
Rick
'88 GTA 350 Full of Leprosy (rust)
Full Exhaust, Free mods, Xtreme Energy cam, Intake Pieces and 2100 RPM TQ
13.39@102.50 MPH
1.90 Sec ----- Best 60FT
104.23 MPH -- Best Trap Speed
AIM HIGH!
Old May 3, 2001 | 10:44 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
</font>
Believe it or not mine used to smoke everytime on start up cause of the seals. After i put in the mobil 1 it stopped. Dont ask me how.
Old May 4, 2001 | 11:40 AM
ONEFINE8T9's Avatar
castrol GTX here 10/30 or 10/40 depending on time of year........
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
http://members.aol.com/j007golden/Mikey89.html
http://www.geocities.com/firebird/myfirebird.html
1985 trans am
factory bright yellow
4 wheel disks
16 inch wheels
305 TPI
power antenna and mirrors
t tops
Old May 7, 2001 | 05:50 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
The #1 motor oil, Royal Purple.
I dont use it yet cause my engine is eating some oil already, but once I do my heads and put new valve seals in ill be using it, as long as my rings look ok Until then i use 10W/30 Pennzoil, they best non-synth oil u can run
Old May 7, 2001 | 08:38 PM
Car: 1985 Trans Am
<font face="Verdana, Arial" size="2">Originally posted by 88blkiroc:
i use 10W/30 Pennzoil, they best non-synth oil u can run </font>
Yuck.... Pennzoil. I'd rather put baby oil in the crankcase!
Old May 8, 2001 | 11:48 PM
FlashGTA
Guest
Posts: n/a
Since Pennzoil changed to pure base it is the best conventional oil. As far as the Mobil 1 not smoking as much as conventional oil past the valve seals it shouldn't. I don't remember why. I used to have a 1985 BMW K100RS motorcycle and when I left it one the centerstand it smoked terrible. The dealer said to put Mobil 1 in and it would stop. I did, and it did, he was right. I remember having it explained why it worked but I forgot.
Old May 9, 2001 | 06:58 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
<font face="Verdana, Arial" size="2">Originally posted by FlashGTA:
As far as the Mobil 1 not smoking as much as conventional oil past the valve seals it shouldn't... I don't remember why... The dealer said to put Mobil 1 in and it would stop... I remember having it explained why it worked but I forgot...</font>
Are you talking about the synthetic Mobil 1? And it costs about $4.50/qt.? I need to replace my valve seals but might try that type of oil instead...
KAM
(by the way, my L98 has lived on Pennzoil all its life without any problems. The intake and valves, etc. were spotless last year when I had the top half opened up. I know - shoulda done the valve seals then...)
Old May 9, 2001 | 12:06 PM
formul8!!'s Avatar
Car: 2004 GTO
Mobil 1 synthetic and K&N oil filters.
Old May 9, 2001 | 12:47 PM
Fastcamaro87's Avatar
ill second that formula8!!
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,TB coolant bypass ,polyurethane tranny and torque arm mounts, k&n oil filter,synthetic oil 10w30, futura GLS super sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
Old May 9, 2001 | 01:21 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I'll third it! I've been using Mobil 1 oil since I had about 70k miles on my IROC, and now I have over 131k miles and it still isn't burning or leaking oil and the oil pressure is 45 cold and 30-35 hot. I'll be pulling out my 305 to swap in a 355 over Memorial Day weekend, and I'll tear apart the 305 to see how clean inside it is.
Greg Westphal
'87 IROC 305TPI/A4
Old May 10, 2001 | 11:17 AM
Ken88GTA's Avatar
Another vote for Mobil 1!!!!!
Old May 10, 2001 | 11:40 AM
Bill87GN's Avatar
I'm tossing this in the general tech/engine dept. because this really don't have much to do with TPIs. Plus, you may get more responses.
-Bill
-=1987 Buick Grand National=-
Almost Jacked Up Like a Mother
*CC 218/218, ported and polished heads (1.77, 1.50), Accufab AFPR, custom DP by Custom Tubes,
Walbro 307 hotwired, Big Mouth cold air intake, 009s, custom PROM and 20psi of fury*
Wanna try me?
-=ICON Motorsports=-
Modertor TPI board
Old May 10, 2001 | 01:19 PM
Spyder's Avatar
Amsoil with Amsoil oil filters
--Spyder--
1992 Camaro RS
LO3, T-56,centerforce clutch, ported and polished heads, Edelbrock Performer Intake, 14X3 Open Element w/ K&N, hiflow cats with two pipes going back, AC delete, SMOG delete, alu drive shaft, 3.73 posi, 170 stat w/ fan switch, STB, Subframe connectors, KYB AGX, Eagle GSC, and poly bushings.
1982 Z-28
327ci CSB, Turbo 350
Old May 10, 2001 | 01:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
<font face="Verdana, Arial" size="2">Originally posted by TransAm223:
Is Mobil 1 tri-synthetic one of the best? What grade, 5w or 10w? </font>
One of the best? Yes. The best? Probably not, and likewise for Royal Purple.
Synthetic marketing materials typically compare their product to conventional petroleum oil, and thus look pretty good. AMSOIL, however, will give you industry standard test results comparing their products to other synthetics. Does that tell you something?
I've been using AMSOIL since 1983. I have yet to wear out an engine with AMSOIL in it.
5W30 is a fairly safe choice for viscosity year-round. As for 10W40's, they have not been recommended for any application since the mid-80's.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/94.6 @ 5800' Bandimere.
Old May 10, 2001 | 06:27 PM
84CAMAROHIGHOUTPUT's Avatar
Amsoil is what I run in both my rides.
Old May 10, 2001 | 08:23 PM
irocbsa's Avatar
Castrol GTX Synthetic 20W-50.
BSA
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old May 10, 2001 | 08:57 PM
ede's Avatar
ede
i use pennzoil, mobil 1, and thanks to 5.7 kid amsoil. i use only ac or wix filters and have never had an oil related problem in many years and miles of use in liquid and air cooled engines.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old May 10, 2001 | 09:29 PM
David M's Avatar
Car: '84 Z28
Engine: L69
Texaco Havoline Supreme 10W40 and an AC Delco PF1218 oil filter.
Old May 10, 2001 | 09:42 PM
Jza's Avatar
Jza
5.5 qts. Mobil1 tri-synthetic and ACDelco PF35L filter here.
xxx3man`
Sep 23, 2015 10:37 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
