swaping pumps....
Old May 13, 2001 | 05:07 AM
88rscaamaro's Avatar
swaping pumps....
iam going to be useing a inline fuel pump instead of the intank style i have now. How would i bypass it? or can i just leave it in there for now?
1988 Camaro RS T-Tops white. Was 2.8 now a mean 406 sbc
(mods)
750 Edelbrock carb
Performer RPM intake
Comp cams Magnum @.50 230-230 lift 480-480
Flowtech 1 3/4 headders with glasspacks for true duals and thats it for now
E.T. 1/4=?
will post when race season starts
2 10' Kicker comps
Kicker 500w amp
Pioneer head unit
2 Jensen 3-way 6x9
along the road
perfomer RPM heads?
NOS
pistons, rods
roller rockers
4.10 rear with posi
91-92 ground effects
Old May 13, 2001 | 07:48 AM
Steves ZZ5's Avatar
You can't leave it in there without having flow problems.
The new in-line pump you plan on installing downstream of the in-tank pump will falter when trying to pull suction from an idle in-tank pump. The in-tank pump is a gerotor design (positive displacement), and is VERY restrictive when trying to pull a suction through it while not running.
You need to remove your in-tank pump and put a fuel pickup of some sort in it's place if you plan on running an in-line pump.
86 Trans Am WS6 Black with tinted windows, shaved door handles
ZZ4, Mini-ram, true duals, LT4 HotCam, AFR 195 heads.
***Too many other mods to mention***
"In the future, cities will become deserts,
roads will become battlefields, and the hope of mankind
will appear as a stranger"
The Road Warrior
Old May 14, 2001 | 02:41 AM
would i be able to just use a section of hose where the pump was at?
Old May 14, 2001 | 02:44 AM
Bort62's Avatar
Why Not use a Fuel tank from a LG4, Mech Pumped car ?
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old May 14, 2001 | 02:49 AM
because i dont want to get a differnt tank and i need this to be cheap for now i just got done putting $3,000 into the motor and after that my money is all gone so i need somthing cheap that will work for right now
Old May 14, 2001 | 07:00 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
A piece of hose will work good, make sure to cut a 'V' in the bottom so it can't stick to anything.
Also remove the pulse dampner if your car has one.
[This message has been edited by JoelOl75 (edited May 14, 2001).]
Old May 14, 2001 | 01:34 PM
ok thank you lot everyone
Old May 14, 2001 | 04:33 PM
poncho9789's Avatar
It might also be a good idea to put a filter in front of the new pump bcuz you don't have a screen filter anymore like the stock pump had, You don't want to kill your new pump from some trash in your tank.
just a thought.
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
john204481
Sep 7, 2015 03:22 PM
TZFBird
Dec 18, 2001 12:47 PM
Monkie
Sep 24, 2001 01:46 PM
BIGD
Mar 28, 2001 12:58 AM
