RPO codes location in a Trans Am
Old May 14, 2001 | 10:09 AM
blak92!'s Avatar
Are they in the trunk? I need to find out the RPO for the gear ratio in the 9 bolt.
Hybrid Black 5.7L 5 Speed
'95 Competition Yellow Corvette Coupe ZF6
Old May 14, 2001 | 10:20 AM
84 t/a 5.0's Avatar
Car: 1984 Trans Am H.O.
Transmission: 700-R4
Axle/Gears: stock 3.73
They might be in the inside of the storage bin on the console
Old May 14, 2001 | 02:39 PM
blak92!'s Avatar
I check the center consol, nothing. Oh well, I will look in the hatch area when I go to the shop tonight. Thanx
Old May 14, 2001 | 03:56 PM
poncho9789's Avatar
The nine bolt has the gear size on the axle case from what I understand.
Old May 14, 2001 | 03:57 PM
poncho9789's Avatar
97 formula w/6speed,cags skipshift eleminator, hurst billet pro shifter, 30#injectors,adjustiable fuel presure regulator,Moroso cold air induction,ported mass air sensor,accell300+ ignition box, accell 9000 wires, bosch platnum4 plugs,flomaster crossflow muffler,Lingenfiter 52mm throttle body,TPIS L98 SuperProfile cam,Crane 1:6 full roller rockers,Edelbrock subframe connectors,Edelbrock strut tower brace.
Other car is a 89 GTA w/700r4w/stage 2 shift kit, corvette servo, B&M mega shifter, TPIS bigmouth intake, TPIS large tube runners, TPIS 52mm throttle body,LT1 24# injectors,GMPP LT4 hotcam,CompCams Pro magnum roller rockers, this car is currently under rebuild and restoration.
Old May 14, 2001 | 07:06 PM
SUPER-SPORT-CHEVY's Avatar
Something you might want to try. I found a Factory delevery sheet "RPO" With all of the information about my bird stuffed under the passenger seat between the springs and foam. Of course its a 19 year old document and crumblemd when I took it out
You might want to give it a try, couldent hurt to look.
SSC
Old May 14, 2001 | 08:02 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I assume its a '92 judging by your "nickname". Email me your VIN @ btripp@sethirdgen.org, I might could help.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
Old May 15, 2001 | 09:59 AM
blak92!'s Avatar
The rear is from a wrecked '88 5.7L GTA, hard top, too old to check? I can get you the vin number sometime this evening.
Old May 15, 2001 | 09:34 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
The RPO codes for the car will tell me nothing about the non-stock rear. You will have to find the three digit code on the axle tube.
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
hectre13
Dec 11, 2023 08:14 AM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
Randomtask2
Aug 13, 2015 01:57 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
antares57
Aug 6, 2015 07:47 AM
