NON THIRDGEN QUES. BUT I NEED HELP!!!
Old May 15, 2001 | 01:53 PM
92GTA's Avatar
Sorry for posting a topic not related to thirdgens but I really need help!!!
It's reguarding my beater car (which I need to get to work while I put my GTA back together!!) a 1993 Toyota Corolla. When you turn the key the starter clicks like the solinoid went out but I changed the starter, it worked fine for about 2 days now it's just clicking again and won't crank!!!
Please help me out guys, I couldn't find any Toyota boards to post on and I need to get to work!
www.TransAmGTA.com THE 3rdgen Firebird Site!
1992 GTA (226 made), 1 of only 18 "Dk. Jade Met." 92 GTA's, My Window Sticker, LB9, 700R4 4-Speed, T-Tops, Grey Leather, every available option except G92, J65 and U1A.
Current Mods/Upgrades: 80 Series Dual Outlet Flowmaster, TPIS Air Foil, K&N Air Filter, and Mobil 1.
Future Mods/Upgrades: None but a complete restoration.
Best Track Time: 14.6sec@96.6mph
"If it ain't broke, fix it til it is!"
Webmaster www.TransAmGTA.com
My 3rdGen Firebird Message Board!
[This message has been edited by 92GTA (edited May 15, 2001).]
Old May 15, 2001 | 02:08 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
All i can think of is the obvious, like bad connection somewhere, or a battery. A lot of help, huh
Old May 15, 2001 | 02:52 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Try checking all of your grounds. (battery, and the cable to the engine....) also, the starter grounds thru the motor, to the battery, pull the starter, clean the mating surfaces, and put it back on.
Hope this helps.
Old May 15, 2001 | 03:37 PM
poncho9789's Avatar
try the altinator to see if it is charging the battery correctly. If that is not it try to hit the starter(lightly) with a hammer and try to start it.If that works go ahead and get yourself a new starter.
97 formula w/6speed,cags skipshift eleminator, hurst billet pro shifter, 30#injectors,adjustiable fuel presure regulator,Moroso cold air induction,ported mass air sensor,accell300+ ignition box, accell 9000 wires, bosch platnum4 plugs,flomaster crossflow muffler,Lingenfiter 52mm throttle body,TPIS L98 SuperProfile cam,Crane 1:6 full roller rockers,Edelbrock subframe connectors,Edelbrock strut tower brace.
Other car is a 89 GTA w/700r4w/stage 2 shift kit, corvette servo, B&M mega shifter, TPIS bigmouth intake, TPIS large tube runners, TPIS 52mm throttle body,Edelbrock ported centerbolt heads,LT1 24# injectors,GMPP LT4 hotcam,CompCams Pro magnum roller rockers,Edelbrock headers, flowmaster crossflow muffler, this car is currently under rebuild and restoration.
Old May 15, 2001 | 08:05 PM
92GTA's Avatar
All connections and grounds are good. A hammer worked at first but not anymore. Could it be the ignition switch??
Old May 15, 2001 | 09:28 PM
Vader's Avatar
<h1>Toyota boards?!</h1> At least I got a little chuckle out of that one.
Anyway, It sounds like you might have found a bad solenoid. If the battery voltage remains at teh cable when you attempt to start, the solenoid isn't switching or the brushes/armature are defective.
Just for grins make sure teh starter is secusrely bolted to the engine. too.
Later,
Vader
"Fear is how I fall, Confusing what is real..."
Adobe Acrobat Reader
[This message has been edited by Vader (edited May 15, 2001).]
Old May 15, 2001 | 10:38 PM
92GTA's Avatar
Vader,
Thanks but that's the wierd thing, the starter is brand new (I put it in myself just a week ago) and I had it bench tested before I installed it and it did work for a couple of days after the install. Damn this is driving me nuts. I'll guess I'll have to take it to a shop
Old May 16, 2001 | 02:47 PM
87RS402's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 92GTA:
the starter is brand new (I put it in myself just a week ago)</font>
That means exactly nothing. Just because the starter is "new" doesn't mean that it didn't go bad. I've put in a reman starter and took it right back out the same day. Somthing could have been loose inside and bound up. Starters are kind of like the old HEI modules, sometimes they last for 5 years, sometimes they last for 5 days.
Old May 16, 2001 | 02:53 PM
92GTA's Avatar
Even if I had it tested when I bought it and tested before I put it in??? Damn that sucks! So should I try yet another starter??
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
Exxon Limited
Aug 9, 2015 08:13 PM
