I hear a rattling noise when i hit the gas
Old Oct 2, 2004 | 06:16 PM
adedirtbiker01's Avatar
Car: 1987 Trans Am
Engine: 305 4BBL
Transmission: AUTO
I hear a rattling noise when i hit the gas.
It doesn't do it all the time but when i really get into it i hear a rattling noise in the back of the car. I checked the exhaust and i dont think its that. my dad seems to think it might be the rear going out of it. I hope thats not true. Anyone with any experience with this problem please give me some idea.
Old Oct 2, 2004 | 06:54 PM
nsimmons's Avatar
sure its not pinging? try some premium gas
Old Oct 2, 2004 | 07:49 PM
Car: 1987 Trans Am
Engine: 305 4BBL
Transmission: AUTO
yeah i put in premium and i know for a fact it wasnt pinging
Old Oct 3, 2004 | 06:49 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Back off the timing some, its probably way too high. It sounds like little rocks in a glass jar, right?
Old Oct 3, 2004 | 06:53 PM
ljnowell's Avatar
Not to say sound isnt deceiving, but we can give the benefit of the doubt.
Things to look at:
U-joints
Anything Rubbing on wheels?
Shielding under the car.
Get under the car, and rattle and shake everything. See if you can find anything rattling. Could maybe be your exhaust at High RPM's, you wouldn't be the first
Old Oct 3, 2004 | 07:18 PM
Car: 1987 Trans Am
Engine: 305 4BBL
Transmission: AUTO
ok. i put the car up on the lift an checked the exhaust. it was able to move. i tightened it up and also put a hose clamp around the catalitic conv. cover to keep it from moving. i drove it that morning and it still did it.
But when i took it out later that day it didn't do it.
I think it only does it under high acceleration at low to mid speeds, (0-30)mph.
Thanks for all the help guys
Old Oct 3, 2004 | 07:26 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Yeap, sounds like pinging to me. Are you getting any codes?? It sounds like the timing is out a bit.
Old Oct 3, 2004 | 07:27 PM
Car: 1987 Trans Am
Engine: 305 4BBL
Transmission: AUTO
wut do u mean by "codes"?
Old Oct 3, 2004 | 07:30 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Is your SES light on in your dash?? Your car is TBI correct???
Old Oct 3, 2004 | 07:57 PM
89IROCZTPI's Avatar
Car: 1989 IROCZ
Engine: Rebuilt 350 TPI
Mine would rattle real bad under heavy load and high accelleration, and come to find out my Knock sensor had gotten the plug knocked off, or looked like it had, put in a new one and a new plug and my rattle stopped.
Old Oct 3, 2004 | 09:12 PM
sellmanb's Avatar
Car: '86 Berlinetta
make sure that your knock sensor is plugged in
Old Oct 4, 2004 | 02:03 PM
Car: 1987 Trans Am
Engine: 305 4BBL
Transmission: AUTO
my car is carbureted
where is the knock sensor
Old Oct 4, 2004 | 02:22 PM
Air_Adam's Avatar
Knock sensor is right near the starter at the bottom of the block.
Fronzizzle
Mar 18, 2019 08:29 PM
xxx3man`
Sep 23, 2015 10:37 PM
1fast91
Sep 8, 2015 01:48 PM
db057
Sep 4, 2015 07:57 AM
