383 with TPI??
Old Nov 7, 2004 | 06:52 PM
19Irocz86's Avatar
Car: 1986 Iroc z z28
Engine: 305 tpi
383 with TPI??
I recently got a 350 4 bolt main for 50 bucks
I plannig on boring it .30 over and then stroking it to 383
maybe a super or turbocharger not sure yet but I was wondering if I should keep it TPI which is what I want to do
but can I get lots more power out of a carb???
Old Nov 7, 2004 | 08:26 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
youll get better driveability outta fi. and with tpi, a torque monster
Old Nov 7, 2004 | 08:47 PM
19Irocz86's Avatar
Engine: 305 tpi
will I need to do any mods with the tpi in order for it to run effectivly???
do I need a bigger throttle body??
Old Nov 7, 2004 | 09:01 PM
ljnowell's Avatar
If you can run a carb without going afoul of inspection, do it. The TPI will hinder performance. Greatly. For the money you spend to make it "better" you could get a great carb intake combo. With your carb properly tuned and your timing right, you will have just as adequate driveability as with FI. Remember cars werent always fuel injected.
Old Nov 7, 2004 | 09:56 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
And theres a reason they aren't carbed today.
Old Nov 9, 2004 | 01:15 PM
19Irocz86's Avatar
Engine: 305 tpi
should I get bigger runners, throttle body, and injectors?
Old Nov 9, 2004 | 02:30 PM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
I think it's emissions, not cost effectiveness though.
Sorry, just playing devil's advocate.
If cost wasn't an option, I'd go with Holley's StealthRam, or a single plane efi conversion. If you are really in a pinch and want to stick EFI, go for the LT1 intake conversion & prom burn.
Old Nov 10, 2004 | 01:40 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I would keep the TPI for now if he already has it. I know, I know, I sell the LT1 intake conversion so why not steer him that way? Well, in his opening post he said he was going with a supercharger or turbo. That changes the rules of induction folks. What was once a hindering small runner TPI intake isn't anymore because of the laws of pressurization. It will run like a raped ape with boost applied. I don't know for sure if changing the intake after that will have a dramatic effect or not but it will run well with stock TPI and boost.
Old Nov 10, 2004 | 09:57 AM
ljnowell's Avatar
As said above, emmissions and other nasty little laws
Agreed entirely.
Old Nov 10, 2004 | 10:34 AM
GOY's Avatar
GOY
Really - I figured you would feel just the opposite being that the length of the runners would only give the pressurized air time to heat to the same tempature as the intake, reducing density. Interesting none-the-less.
Old Nov 10, 2004 | 01:14 PM
19Irocz86's Avatar
Engine: 305 tpi
thanks for all the help guys I have decided to keep my tpi for the 383
Old Nov 11, 2004 | 09:34 AM
19Irocz86's Avatar
Engine: 305 tpi
well guys I was looking around prices to build a 383 stroker and its a little more than I want to spend at the moment
So I think I am just going to build a strong,fast, **** eating 350 for the time being.
which starts my topic over "how about the tpi on a 350"???
sorry for the sudden mind change
Old Nov 11, 2004 | 11:14 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
TPI isnt all that horrible
If your on street, torque is what ya want.
all this talk about TPI choking motors makes it sound like its
out of the stone age.
and a LT1 setup is quite similar to a TPI, without the long tube runners,
and the higher compression motors the LT1 came on.
if your gonna go with blower, ATI makes a hell of kit
for a L98 TPI with a excellent boost warranty.
OH! what is the 350 out of? 50 bucks!??
same applies if your gunna supercharge.. even tho a built 383 is
is chocolate icing with a cherry on top!!
Old Nov 14, 2008 | 02:31 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
Re: 383 with TPI??
I would have to suggest ditching the TPI if you dont have emissions. I went down this road and have been kicking myself ever sense. I built a fully forged 383 with AFR 195 eliminators, edelbrock base, slp runners, and a ported plenum and its still chokin the living $#!% out of it on the big end. Ran a best of a 14.4 at a track at 5,800ft. I am now in the process of switching over to an rpm air gap and a 750 double pumper.
Old Nov 14, 2008 | 04:09 PM
TPI's Avatar
Re: 383 with TPI??
Wow, this thread is four years old! .. holy crap!
Ever hear the expression the difference between insanity and genious is
only measured by success? There is a quite few people who have built very nasty 383 Tuned Port engines. But, compare that to the number of people who have tried and failed... yea.
14.4? So you spent thousands of dollars only too shave 4 tenths off a
factory TPI car? I dont think I could blame TPI for that.. no offense.
Then again 5800feet does suck.
Old Nov 15, 2008 | 12:48 PM
danziger's Avatar
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
Re: 383 with TPI??
I ran the stock TPI on my mild-383 and it was probably costing me 40+rwhp. However, the giggle-inducing torque was quite fun...except for my tires.
toronto formula
Nov 10, 2015 06:17 AM
bdads
Aug 24, 2015 06:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
