HELP my car is falling on it face!
Old Nov 14, 2004 | 08:26 PM
eXesiv|83ta's Avatar
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
Hey guys,
I have a problem. Last week my car started actin funny. I can no longer push the pedal down past about 1/4 throttle or it just dies. The only thing I can do is lightly press the pedal. If I try to hammer it the car dies and after a certain point of pedal depression it pretty much just drowns and occasionally it backfires. At first I thought it was ignition problems so I trouble shot it and replaced the plugs, rotor, cap, and put a new fuel filter on it. I had the ecm amd the coil checked out and they are fine. I cannot figure out what is wrong. The car is an 83 trans am with a 305 TBI the crossfire. Me and my brother are pretty good with cars and I have asked a few people I know and we can't come up with answers. If anyone has had this problem or can help please lemme know what it is that I can do.
And I forgot something. The car seems to run fine while the engine is not warmed up. I drove the thing into town to pick up a fuel filter and it ran fine for about 25mins before it started to act up again.
Old Nov 14, 2004 | 09:08 PM
sellmanb's Avatar
Car: '86 Berlinetta
it's fuel related. Change out fuel filter(s).... I bet it's your fuel pump though. It should be the block-mounted type though, which should take like an hour to replace, and will cost about 20 dollars new lol.
Old Nov 14, 2004 | 10:09 PM
Engine: 355 chevy
I'm pretty sure the pump is in the tank cuz the lines go right to the filter I replaced and to the throttle bodies.
J.
Old Nov 14, 2004 | 11:01 PM
sellmanb's Avatar
Car: '86 Berlinetta
well, there's an easy way to solve that then...
go to your engine bay, look on the passenger side, on the block, should be right behind the smog pump. Not sure but I think there might be a helper pump inside the tank too or something...? Not sure.
Old Nov 14, 2004 | 11:23 PM
Engine: 355 chevy
If i'm not mistaken that is exactly where the fuel filter I replaced is at. And there isn't a smog pump on my car. It was seized when I bought it. Can anybody prove or disprove this?
Old Nov 15, 2004 | 12:27 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
He's got CFI. He won't have a mechanical fuel pump. My car was originally a CFI. he's got an intake pump. The backfiring almost sounds timing related. May want to look into that. If you have the means to check fuel pressure, I would suggest doing so.
Where in Grand Rapids are you? I might be able to take a look at it later this week.
Old Nov 15, 2004 | 12:38 AM
radiateu2's Avatar
any error codes?
Old Nov 15, 2004 | 03:54 PM
Engine: 355 chevy
Unfortunately the car is on the other side of the state. I managed to get it there on a 4.5hr trek that usually takes 2. I can't work on the car over here due to a lack of tools and the apartment complex says we can't.
No there were no error codes as far as I know, none of the idiot lights came on and I don't have a code reader even if one came on.
Old Nov 16, 2004 | 06:38 PM
Super_GTA's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: 357 Tuned Port Injection
Transmission: Borg Warner T-5
Axle/Gears: BW 3.45 9-Bolt
I haven't worked on crossfire before, but it sounds like it's running pig rich. If there is a throttle position sensor, try adjusting that back and see if that helps. Could also be a bad 02 sensor.
Old Nov 16, 2004 | 11:34 PM
Engine: 355 chevy
I don't know if its running rich or not. I pulled the original plugs and if anything they had the lean (hot) telltale signs. White deposit on the ground and partly deformed insulator.
Do you guys think that it might also be the fuel pump in the tank? When I get home this weekend I will check the sensors. I dunno if mine has a throttle position sensor. If it does then does anyone know where I should look for it?
Thanks,
J.
Old Nov 17, 2004 | 10:05 AM
Super_GTA's Avatar
Well... if it runs fine while cold, I would recommend having the ignition control module tested. It should be in the distributor. Take your distributor to your local NAPA and have then test it. It sounds like that may be your problem.
Old Nov 17, 2004 | 10:40 AM
Engine: 355 chevy
I did that
I have replaced or had everything checked out but the wires in the ignition system.
J
Old Nov 17, 2004 | 11:18 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
If it turns out to be the pump, I've got a replacement CFI pump (currently installed) that will not be used.
Old Nov 17, 2004 | 11:27 AM
Super_GTA's Avatar
How is your oil pressure?
Old Nov 17, 2004 | 01:20 PM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
Axle/Gears: stock/3.42
this is where your throttle position sensor is located. (if the pic uploads corectly????)
Old Nov 17, 2004 | 01:22 PM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
I have the 1982 camaro shop manual. If you need any help locating things on that crossfire set up let me know. I just have limited time on computer but i will get back to you
Old Nov 17, 2004 | 05:09 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Whens the last time you changed your fuel filter? It might be totally plugged up.
Old Nov 17, 2004 | 05:11 PM
Engine: 355 chevy
Alright thanks man I really appreciate it.
J.
Old Nov 17, 2004 | 05:14 PM
Engine: 355 chevy
Not to get pissy but i'm pretty sure that I said in the original post that the fuel filter was changed. I didn't however change the bag type filter that is in the tank. I would rather not venture there yet because I have to take the rear end and exhaust off to get to the tank!
Oh and the oil pressure is fine also.
Justin
Old Nov 17, 2004 | 06:32 PM
Air_Adam's Avatar
Danm me and my skimming, lol. I read the whole original post, but most of the others I just skimmed through.
Maybe try running some fuel system cleaner through it? Or maybe clean out the TBs with some O2-safe carb spray?
Old Nov 17, 2004 | 08:17 PM
Super_GTA's Avatar
Try adjusting the throttle position sensor (tps) back and see if that helps.
Old Nov 17, 2004 | 10:24 PM
Engine: 355 chevy
alright I will do that and get back to ya guys.
Old Nov 18, 2004 | 03:15 PM
Air_Adam's Avatar
Have you checked for a vacuum leak yet? Might be a good idea.
What color are your spark plugs?
Old Nov 18, 2004 | 08:07 PM
Engine: 355 chevy
I changed the plugs but they looked a little white. Not a lot off of the normal plug wear color of tan.
Old Nov 18, 2004 | 08:09 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
A little white can mean a little lean.
Old Nov 18, 2004 | 11:50 PM
Engine: 355 chevy
ya i know but i dunno what to do about it.
Old Nov 19, 2004 | 02:20 PM
RMC030's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.7 Tuned Port Injection
Transmission: Borg Warner T-5 5 speed
Hey check out my problem, it seem to be going around
Old Nov 19, 2004 | 05:15 PM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
To me it sounds like a lean condition due to the backfiring. I would check the fuel pressure/volume(tape the gauge to the window if you can and drive it watching for a pressure drop)and if possible scan the car and look at the fuel trim and O2 values during the event.
Old Nov 20, 2004 | 03:54 PM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
I agree. If you have never replaced the fuel pump, thats what you need to look at next. I talked to the guy who owned my car before me (mine was a crossfire), And he seemed to remember similiar problems when the fuel pump went out on it (7 years ago) It would idle all day long but soon as you hit the "go pedal" it would raise hell and die out. He replaced the pump and no problem since? But before I went to that hassle I would try to hook up a fuel pressure gauge and see what is going on for sure because a fuel pump is NO FUN on these cars
Old Nov 21, 2004 | 09:19 PM
Engine: 355 chevy
lol,
tell me something I don't know(fuel pump being no fun). :lala:
Old Nov 21, 2004 | 11:21 PM
hungry4des's Avatar
Car: 89 IROC
Engine: 5.7 TPI
My car did this. It was TPS. Get new one. n/m
n/m
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
