Car cuts out under acceleration
Old Jun 5, 2001 | 02:28 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
When accelerating my car cuts out usually at about 3,000 rpm, I notice that the radio distorts and my tach jumps up and down about 500 rpm both ways I think it is an ignition problem what should I look for???
91 Z28 5.7l Camaro
T-56,McLeod Street Clutch, Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
Old Jun 5, 2001 | 07:16 PM
akuma's Avatar
Hi Chris,
My car had a clogged catalitic conveter and it wouldn't go over 3200 rpms. I would start at your distributor and check for cracks, it sounds like your arching somewhere, that could cause radio interference.
Old Jun 5, 2001 | 08:01 PM
Vader's Avatar
Chris,
Don't overlook the coil and ignition primary wiring as well as the plug and coil wires.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
mustangman65_79
Aug 13, 2015 07:36 AM
Sherpajames
Aug 7, 2015 06:56 PM
