starter
Old Dec 6, 2004 | 02:20 PM
350WHT's Avatar
Car: 1992 camaro RS
Engine: sbc 350
Transmission: th350
starter
recently i posted about my starter and they said that there were problem child for these blocks to not be properly alinged if this is one how do i fix the problem.
thanks
Old Dec 6, 2004 | 02:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I don't recall seeing your other post (a link would be helpful), but if it's what I think it is (mount bolt holes not properly drilled), about your only recourse is to have a machine shop plug the existing holes and re-drill and tap in the proper locations. This is an engine-out-of-the-car operation (although a sporty shop might attempt it in the car).
Old Dec 6, 2004 | 07:16 PM
sellmanb's Avatar
Car: '86 Berlinetta
I'll take a wild guess that what they meant was that the starter needs to be properly shimmed. Normally the boxes for new starters will have shims in there... but the auto place doesnt give them to you for some reason .
Old Dec 7, 2004 | 01:58 PM
350WHT's Avatar
Car: 1992 camaro RS
Engine: sbc 350
Transmission: th350
ive tried every shime there is over a million times i even tried putting bushings in the starter to help keep it in place, im out of ideas this is the only thing keeping me from being able to drive my car. If anybody has anyother ideas as to what it could be please help?
heres whats going on the starter will turn over fine for about 5 trys then just go to **** it either catches or misses the fleplate somtimes it just gets stuck, put a shime in it itll be fine then act up agian ive even changed flexplates in it hoping it was it but no that didnt help either.
Old Dec 7, 2004 | 04:26 PM
sellmanb's Avatar
Car: '86 Berlinetta
Is it a new starter?
If not, the bendix could be half broke or something.
Old Dec 7, 2004 | 06:38 PM
350WHT's Avatar
Car: 1992 camaro RS
Engine: sbc 350
Transmission: th350
this is my fifth starter, it can be the appendix u would think that maybe i would get lucky with one. but they are remanufactured
Old Dec 7, 2004 | 07:30 PM
350WHT's Avatar
Car: 1992 camaro RS
Engine: sbc 350
Transmission: th350
(bendix)
Old Dec 8, 2004 | 07:30 PM
350WHT's Avatar
Car: 1992 camaro RS
Engine: sbc 350
Transmission: th350
does anyone have anymore ideas?????
Old Dec 8, 2004 | 10:12 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Is the motor stock??? has it ever been line bored??
I will only use GM remans... I have never needed shims with them
Old Dec 9, 2004 | 01:21 PM
350WHT's Avatar
Car: 1992 camaro RS
Engine: sbc 350
Transmission: th350
no, it has a stock bottom end on it, been bored .60 over and has prefomer maifold, flowtec hearder holly 600 carb, forged 9.1 pistons. powerforce harmonic damperner, um.......that should be it
Old Dec 9, 2004 | 02:09 PM
five7kid's Avatar
At the risk of repeating myself:
The mount bolt holes were not properly drilled. About your only recourse is to have a machine shop plug the existing holes and re-drill and tap in the proper locations. This is an engine-out-of-the-car operation (although a sporty shop might attempt it in the car).
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
