Approximately how many degrees is one turn
Old Jun 7, 2001 | 10:54 PM
BowtieFever's Avatar
When adjusting the timing, how many degrees does one full turn make on a distibutor cap.
Old Jun 7, 2001 | 11:17 PM
Guest
Guest
Posts: n/a
Well look at it this way, if you turned it one full turn from being right at TDC #1, it would be back at TDC #1.
In case you didnt know, there are 360 degrees in a circle.
Old Jun 7, 2001 | 11:22 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Someone's a little bit of a smart-a**. (no flame intended)
I can see how it might be a little confusing.
Old Jun 7, 2001 | 11:34 PM
Guest
Guest
Posts: n/a
I couldnt resist
No flame intended here either... not all of us are mathematicians
Old Jun 8, 2001 | 07:53 AM
ede's Avatar
ede
i'm confussed to, i thought 1 full turn was 360* too.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jun 8, 2001 | 08:09 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Unless he's talking about crankshaft vs cam degrees. The crankshaft spins 2x faster than the cam, so for every complete turn of the cam, the crank spins twice.
(Had to fix the goof up...)
[This message has been edited by JoelOl75 (edited June 09, 2001).]
Old Jun 8, 2001 | 08:37 AM
irocbsa's Avatar
If you want to get really confusing we could start converting to radians.
bsa
[This message has been edited by irocbsa (edited June 08, 2001).]
Old Jun 8, 2001 | 09:27 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
2pi radians
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Old Jun 8, 2001 | 09:58 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Since (as someone mentioned above but then putzed the conclusion) one full turn of the distributor is 2 full turns of the crank, which would be 720°. During one complete revolution of the dist shaft, #1 TDC occurs twice: once at #1 firing, and once when #1 comes to the top of the exhaust stroke and begins its intake stroke.
ICON Motorsports
Old Jun 8, 2001 | 01:03 PM
Steves ZZ5's Avatar
<font face="Verdana, Arial" size="2">Unless he's talking about crankshaft vs cam degrees. The camshaft spins 2x faster than the
crank, </font>
Actually, the CRANKSHAFT spins two times faster than the CAM.
<font face="Verdana, Arial" size="2">so for every complete turn of the crank, the cam (and distributer) spins once.</font>
Actually, for every complete turn of the crank, the cam and distributor turn HALF a turn.
<font face="Verdana, Arial" size="2">During one complete revolution
top of the exhaust stroke and begins its intake stroke.</font>
Actually ...TDC in mechanical terms does occur twice per each cam revolution. But, when setting an engine at "TDC", it's #1 piston is set at the compression stroke of the crank when said piston is at mechanical TDC. This is the common term (and engine position) for TDC.
Easy terms:
the Cam and Distributor spin ONCE (360°) for every TWO complete rotations of the Crankshaft.
Hence, as the question asks:
1) The distributor rotates a complete circle (360°) for every cam rotation.
2) The distributor rotates half a circle (180°) for one complete crank rotation.
This is getting crazy...Hehehhhh.
86 Trans Am WS6 Black with tinted windows, ZZ4, Mini-ram, true duals, LT4 HotCam, AFR 195 heads.
***Too many other mods to mention***
"In the future, cities will become deserts,
roads will become battlefields, and the hope of mankind
will appear as a stranger"
The Road Warrior
Old Jun 8, 2001 | 05:14 PM
irocbsa's Avatar
Or if you have Calculus on the brain: for every 2Pi radians turn of the distributor you have 4Pi radians turns of the crank. Sorry, have been in Cal 3 class all day and I want somebody else to suffer with me.
bsa
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
skeltor
Feb 2, 2016 10:37 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Jorlain
Oct 8, 2015 01:57 AM
383cam
Sep 9, 2015 06:01 AM
