Running rich, White/blue smoke
Old Jun 12, 2001 | 10:49 PM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
When I start my car up after it has been sitting for a while, it will chug a bit of white/blue smoke. My dad thinks its valve guides, but i think its something different. My car runs rich after i tuned it up and adjusted my timing which helped, but my choke plate always stays open. I bought a choke thermostat and havent put the new one in because i cant figure out why the plate wont close. Is there a certain position the choke thermostat be set at? Also, since my car hasnt had a choke (i took it off to replace it with the new one but havent put the new one on), the check engine light hasnt been plauging me, nor has the choke light. Since i have the emissions test coming soon, i wanna make sure i have the basic stuff changed to lean it out, hopefully this info is enough to diagnose the problem. Thanks
1987 Z28
305 4 barrel rochester quadrajet
K+N air filter
Old Jun 12, 2001 | 11:01 PM
MrJ's Avatar
MrJ
Rich smoke = black smoke. It sounds like your dad is right, your valve guides/seals probably are worn. Mine smokes a little in the morning after letting it sit overnight.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
ported TPI setup
Built on Wednesday
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
