compression & quench with pump gas
Old Dec 27, 2004 | 11:57 PM
meangene83's Avatar
Car: 91 formula
Engine: 355
Need advice, I have two short blocks ready to go in my garage, can't decide which one to use. One is a stock(re-ringed) L31 engine with 13cc dish pistons and standard .025 deck clearance. The other is a 355 with 2 relief flat hypereutectics with 5cc releifs and standard .025 deck clearance. I have the LT4 hot cam, vortec heads, 1.6rrs, 1 3/4 slp headers and will probably use my edelbrock intake and demon carb 'til I can afford a stealth ram. Now my question is which route would you take---- with the L31 block and .015 shim gaskets I'll have 9.395 static comp. 8.138 dynamic and .040 quench----- with the 355 and .015 gskt 10.395 SC 8.987 DC & .040 quench ----- 355 and .028 gskt 10.063 SC 8.706 DC & .053 quench ---- 355 and .039 gskt 9.802 SC 8.484 DC & .064 quench. Decking one of the blocks or changing pistons isn't really an option right now, trying to use what I have now. sorry so long
Old Dec 28, 2004 | 01:10 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
By far the flat-top 355
Old Dec 28, 2004 | 05:40 PM
meangene83's Avatar
Car: 91 formula
Engine: 355
OK i hear ya there, but which head gasket do you think I should use? Will I be asking for detonation with the quench at .053?
Old Dec 29, 2004 | 02:37 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Run the thin gasket for 10.4:1, you'll be fine on pump gas with that.
Old Dec 29, 2004 | 10:21 PM
meangene83's Avatar
Car: 91 formula
Engine: 355
thanks guys, i'll try it and keep my fingers crossed
1986Z28OWNER
Dec 13, 2015 10:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
NWAsonoma
Aug 18, 2015 05:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
355tpipickup
Aug 13, 2015 07:35 AM
