unmountet starter. found fragments of a bearing in there....
Old Jan 5, 2005 | 10:48 AM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
hello,
i disassembled my starter today because it wont turn the motor anymore. and thats what i found in there...
could it be the "release bearing" (dont know the word )
thanks,
nebu
Old Jan 5, 2005 | 11:02 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It used to be the Bendix. (also known as starter drive)
Just get another starter.
Old Jan 5, 2005 | 11:07 AM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
thx but what happened to the rest of this starter drive?
Old Jan 5, 2005 | 11:14 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Hard to say....
Go compare what's left of your starter, to the one you're about to buy; and see what's different. Maybe some of it's still stuck to the starter. Maybe some of it fell out on the ground somewhere. I can't see it quite well enough from here to tell any of that. All I can tell is, your Bendix came to pieces.
Old Jan 5, 2005 | 11:26 AM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
here are some pics of the starter.
so what is this bendix?cant see any damage done to the starter.
nebu.
Old Jan 5, 2005 | 11:37 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It is the piece with the teeth on the end that slides along the motor shaft.
The ball bearings came out of the wide silver-colored ring that's right next to the teeth. That's a one-way clutch system, that's supposed to connect the teeth to the shaft, but allow it to spin faster than the shaft if necessary (like when the engine starts running but the starter is still engaged). No doubt you can just grab the teeth part and just spin it in either direction now, with little or no resistance.
Old Jan 5, 2005 | 11:43 AM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
ah cool, thx but how did the ball bearings came out of this silver ring with no damage to it?
nebu.
Old Jan 5, 2005 | 02:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The backside doesn't look undamaged, from what little can be seen in your photo.
One side gets pushed over, the guts fall out, then it re-centers.
83 Crossfire TA
Jan 3, 2016 01:26 PM
SlowAZ28
Sep 2, 2015 05:19 AM
bjpotter
Aug 12, 2015 06:06 PM
rsrmoore
Aug 7, 2015 08:44 PM
antares57
Aug 6, 2015 07:47 AM
