Book: How To Run 11 Second E.T.'s
Old Jun 23, 2001 | 07:40 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Anyone one have/familiar with this book? It is on page 5-E of my Jegs (www.jegs.com) catalog for $19.69 (PN 762-2020) It is specific for 82-92 Camaro / Firebirds.
http://www.jegs.com/photos/7622020.jpg
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Jun 23, 2001 | 09:46 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
yep I have it. See this post
https://www.thirdgen.org/messgboard/...ML/010171.html
near the bottom
Old Jun 23, 2001 | 10:48 PM
Grand Prix's Avatar
Got it, book sucked. 1st, it has very little theory. Its more like a receipe than a car book. He lost about 75% of the streetability going from high 11's to very low 11's. The car was actually a descent street rod at high 11's, by low 11's I would actually like to see him drive this car every day and not lose his hair. The car did run fastest without shifting at high RPM but the engine still would be a pig at 2000RPM. He also made a few sacrifices that you may not want to make. Like power steering, gone. Power brakes, gone. Sway bars, gone. All the springs were soggy 6cyl springs making certain the car sat low and handled worse than a Grand Am. Save your money, buy a book that makes you understand why a car is faster. Then use 10 year newer technology to build one that can run 11's and still handle and drive like a new stock Trans Am.
Old Jun 24, 2001 | 01:00 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Hey, that sounds like my car. If it was still street legal I wouldn't want to try driving it on the street.
You can look at it 2 ways. Built it to run low 11's cheap but not very street legal or build it to run 11's and be street legal for a lot more money.
You could build a car that runs 8's and be street legal and a daily driver if you have enough money.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Jun 24, 2001 | 01:20 AM
Bort62's Avatar
Money, Or a Supra.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 14.82 @ 91.1
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Jun 24, 2001 | 01:29 PM
rondubbs's Avatar
hey john,
if you want it, i'll sell you mine..
email me. rondubbs@aol.com
[This message has been edited by ron rizzotti (edited June 24, 2001).]
Old Jun 24, 2001 | 05:52 PM
Engine: 4.0L
No thanks, I just wanted to know more about it and how old it was. Turns out it's probally out of date. I'm using TPI and he was a carb guy. Not the same. Thanks anyway.
86 Camaro Sport
My Camaro Project
Old May 19, 2020 | 02:09 PM
ez2cdave's Avatar
Car: 1989 Camaro IROC Z
Engine: 383, soon to be an LS Stroker
Transmission: 700R4 - Switching to 4L80E
Axle/Gears: 10-Bolt/3.42 will be Moser 12-Bolt
Re: Book: How To Run 11 Second E.T.'s
HERE is the book . . . 19 years later - LOL !
EDIT: Deleted link
Old May 19, 2020 | 11:02 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Book still has copyright protections.
Old May 20, 2020 | 12:32 AM
Drac0nic's Avatar
I looked it over. A lot of stuff has changed since it was released probably the notable rise of supercharging, aftermarket ECUs/ECU tuning being more of a known quantity, the price coming down on decent aftermarket 400 CID blocks, connecting rods, valvetrain enhancements (springs and cam lobe profiles) and the availability of over drive transmissions of high quality. For the era this conversation was created in that would have been a wickedly fast car for the street although the stage3/4 stuff I Wouldn't want to do on the street such as run 32 degrees of locked timing on a 400CI engine. I can't imagine that was a fun engine to crank at all. I'd much rather build something supercharged (even blow through) than that setup on a 355 or even a 305. You'd end up with a far more streetable setup honestly.
Something else that I found interesting was they were running 64cc heads with irons and 70cc with the AFRs. Maybe the flow increased the DCR or something? Seemed off to me.
Old May 20, 2020 | 12:08 PM
ez2cdave's Avatar
To the MODERATORS.
Greg Marietti was contacted by me and others on the Forum, in 2014 . . . He was fine with the book being scanned & posted.
Read it & weep . . . https://www.thirdgen.org/forums/tech...bird-book.html
Dave F.
Old May 20, 2020 | 12:24 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Originally Posted by ez2cdave
To the MODERATORS.
Dave F.
Sorry but there is zero objective evidence in that thread that you received permission to post his material. A post saying "I emailed him and he said ok" is not a green light. My kids do that all the time. That thread started in 2008 and ended in 2014 and is just now coming back to light 6 plus years later. I am not trying to be mean, but its not our material to post without him giving us consent. If you did that to any other author, there would be a cease and desist issued in no time.
Old May 20, 2020 | 12:30 PM
ez2cdave's Avatar
I just emailed him, asking for permission to allow me, personally ( by name ), to post the book online, anywhere, free of charge. If he grants that permission, I will repost it,
Waiting for his reply.
Dave F.
Old May 20, 2020 | 12:37 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Dave F.
That's fine. If he clearly grants permission I will reopen the thread and restore the images.
Old May 20, 2020 | 12:40 PM
ez2cdave's Avatar
I also asked him if he has a better copy available . . .
Old May 20, 2020 | 02:28 PM
ez2cdave's Avatar
Shifty Capone,
Greg Marietti has given me permission to post his book.
Rather than take my word for it, I sent you an email with his email address.
Please email him, ASAP . . . Thanks !
Dave F.
Old May 20, 2020 | 02:51 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I received an email stating his permission. The other thread has been unlocked.
Old May 20, 2020 | 03:00 PM
ez2cdave's Avatar
And, now, with no further ado and with FULL PERMISSION from Greg Marietti. . . Here is the book !
Old May 20, 2020 | 03:02 PM
ez2cdave's Avatar
Continued . . .
Old May 20, 2020 | 03:04 PM
ez2cdave's Avatar
Continued . . .
Old May 20, 2020 | 03:05 PM
ez2cdave's Avatar
Last part . . .
Posted with FULL PERMISSION from Greg Marietti . . .
Dave F.
Old May 20, 2020 | 03:43 PM
Drac0nic's Avatar
Shouts to Matt that's a neat piece of history. People don't understand how far we've come in the last 15-20 years.
Old May 20, 2020 | 04:28 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
How to run 11's in your F-body. Page 20: Get yourself a bigger engine
I don't know about you, but that feels little bait and switch. LOL!
Old May 20, 2020 | 04:33 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
And if that doesn't work then go to Step 2: Get yourself an even bigger engine.
Old May 20, 2020 | 04:46 PM
ez2cdave's Avatar
The name is Dave and I am the one who secured the permission from Greg Marietti, not Matt .
Old May 21, 2020 | 11:34 AM
BOOT77's Avatar
Thx for sharing and Thx to the author for giving your permission. I have several automotive books and will check this one out when I get a chance.
Old Feb 9, 2021 | 05:19 PM
ez2cdave's Avatar
duplicate . . . sorry
Old Feb 9, 2021 | 07:16 PM
ez2cdave's Avatar
Remember . . . "There is no replacement for displacement" ( an old saying, probably before your time - LOL ! )
Old Feb 9, 2021 | 07:54 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
My grandfather was born in the 1800's and fought in WWI. Beat that peach fuzz.
Old Feb 9, 2021 | 10:07 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Axle/Gears: Ford 9" with 3.89
My car runs low 11's on motor.
I street drive it.
Drove to the last race of the year and ran a 5.72 (in the 1/8th), which is about 8.98-9.03 in the 1/4, with a shot of spray.
It takes the right parts (money) and time!
Old Feb 9, 2021 | 10:36 PM
ez2cdave's Avatar
My father has a direct bloodline ancestor that was the cabin boy, William Latham, on the Mayflower . . . My father is 93 and a WWII vet . . . My grandfather ( deceased, naturally ) was born in 1882 and was an Army railroad engineer, in WW1.
Old Feb 9, 2021 | 10:48 PM
ez2cdave's Avatar
I street drive it.
Like the old saying goes . . . "Speed Costs Money - How Fast Do You Want To Go ?" - LOL !
Old Feb 10, 2021 | 12:01 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Touché
vortech305
18
Nov 27, 2001 10:52 PM
camaro6spd
Sep 14, 2001 07:04 PM
pygmalion
Jun 29, 2001 08:51 AM
scott87conv
Apr 27, 2001 10:09 AM
LottaBallsCamaro
Apr 7, 2001 11:01 PM
