What cam would you put in this motor?
Old Feb 9, 2005 | 10:04 AM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
ZZ4 bottom end, Trickflow CNC 23 degree heads, 1.6 full roller rockers(will swap to 1.5rr if necessary), Holley Stealth Ram, 3200rpm stall, 3.91:1 gears. I need a hydraulic roller cam. The car is a weekend warrior that will possibly see the strip 5 times a summer and cruise on the weekends. Its not a daily driver. I have the LT4 Hot Cam now and it seems a bit small. I am looking for high 11's with this setup but I do not wanna have to spin it to much past 6000rpm to get the power out of it. I am concerned about valve float also with the hydraulic setup so I will be installing a Comp Cams Rev Kit. I will be doing my own prom tuning also. Any suggestions? Thanks!!
Old Feb 9, 2005 | 11:53 AM
Car: 1989 Iroc-Z
Engine: 350ci SBC
Anyone?
Old Feb 9, 2005 | 01:24 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
Well I just got off the phone with comp cams helpline and they recomended the XR288HR for my setup:
236/242 duration
.520/.540 lift
110 lsa
978 springs and the 3136 timing chain. Does anyone see anything wrong with this setup? Are those springs too much for a hydraulic roller? IS this cam gonna be tunable with a 730 ecm?
Old Feb 9, 2005 | 02:06 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Is that their "extreme" cams? I wouldn't use them if so, they have very steep lobes.
Old Feb 9, 2005 | 02:20 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
yea its their extreme energy XR288HR. Why wouldn't that be a good choice?
Old Feb 9, 2005 | 02:27 PM
pasky's Avatar
Well, its my personal preference, when you deal with a steep lobed cam like the Xtreme grinds, your power falls very quickly after it reaches peak unlike ramped cams. For instance, my 306 actually peaks at 6200 rpm, but it only drops off 7 hp at 6500rpm. If the Xtreme grinds peak at say 5900, your gonna see a 30-45 hp drop at 6000-6100 rpm. If thats what your using it for, by all means go for it, I personally don't like steep cams. This gets discussed quite often at Camaroz28.com. Let me know if you need more info and I can post some threads. Im headin to lunch .
Old Feb 9, 2005 | 02:58 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
Yea could you post more info please What is the CC306 cam? What are its specs and where can you get it?
Old Feb 9, 2005 | 03:00 PM
anondude13's Avatar
I'd like to have the 306 DD file if anyone knows where I can get it.
Old Feb 9, 2005 | 07:02 PM
pasky's Avatar
Comp Cams 306:
230/244 (1.5 rockers) .510/.540 112 LSA
I love it . Bad boy makes power in the 6000's.
XE grind 230/236:
He is explaining the sudden drop in power due the steep lobes:
http://web.camaross.com/forums/showt...ight=230%2F236
cc306 vs 230/236 XE
There is more, just don't have time to get them.
The main advantage of the CC306 is its long exhaust duration and lift. Since chevy heads exhaust flow usually blows, it really helps out, once you port your heads and your exhaust flows better, the cc306 will still be powerful, but not as good as other grinds. Nothing wrong with an extreme grind cam, just not my cup of tea.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro71633
Sep 1, 2015 10:24 AM
cstrobel65
Aug 15, 2015 10:19 AM
slade5612
Aug 11, 2015 07:19 PM
Fronzizzle
Aug 9, 2015 01:15 PM
