need help choosing cam
Car: 91 rs
Engine: 250
Axle/Gears: stock??
ok guys i gusse all my cam i've pickedout are junk so i'm asking you what would be good for my setup. i'm runing a edle performer intake holley 750 vac secondarys fully ported 416 heads with screw in studs 1.5 rr's .hooker comp shorties springs good upto .600 lift i'm looking for a higher rpm cam i have a fresh bottom end i'm finishing up right now i'm willing to sacrifice some lower end for some more mid to high end power not to worried about price this is a flatt tappet cam so ussally thier not to espensive
edit: this is on a 4bolt main 350
Car: 4
Engine: 6
Transmission: 5
One of these things is not like the other. One of these things, doesn't belong.
I'd suggest a XS274S..... 236°/242°, .501"/.510" ..... and some other intake, such as a Perf RPM.
Car: 4
Engine: 6
Transmission: 5
What will happen, is if you put a cam in there that sets the motor up for top end, is you will get a motor that's a pig down low because of the cam; and a pig up high because of the intake.
They need to match.
Expect any cam you put in, to make the car slower; until you get an intake that's actually significantly better than a stock one. That would include the one I mentioned. You will hate it.
They need to match.
Car: 91 rs
Engine: 250
Axle/Gears: stock??
well at this exact moment in time i just need to get it together and this is what is holding me up. the intake will have to do for now. i will be getting a edle rpm air gap intake which will mostly liely be exactly were i want my cam. in that exact power band range and intakes arn't hard to change so i do what i can with what i have
Car: 4
Engine: 6
Transmission: 5
I wouldn't use that, if it was my motor; not with any cam, not if I got it for free. But that's just me.
Seems like those things are always available "for a real good price" these days.... everybody that has them, is getting rid of them. There's actually a good reason for that. Which is, just about anything else, runs better. Although, it might be somewhat of a step up from a Performer, as far as opening up the intake tract and letting the motor breathe a bit.
