76cc heads ?'s
76cc heads ?'s
I have a 74 350 block with 76cc heads what the experts (you guys) do to maximize performance with these heads from start (bare) to finish on a block that has .30 JE pistons steel crank ,new rods and a comp cams xe268 cam? thanx guys.
Nothing will realy maximize performance with those heads they are low compression. The 76cc heads are fine for a non performance engine "dads old beater" But not for a performance aplication. I would go for 68cc and lower.
SSC
I just had one of those after thoughs
These would be great heads for a supercharged setup but thats probably not in your plan.
[This message has been edited by SUPER-SPORT-CHEVY (edited July 01, 2001).]
SSC
SSC's pretty much dead on. Even if you zero deck your block, you're still only going to have 9:1 CR with -6cc flat tops. With a zero dec, -6cc flat tops, and milling the heads .02", that would bring you up to around 9.4 or 9.5:1. I don't think you want to mill the heads that much either!
-Jason M. 1991 Camaro Z28
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
What kind of a stupid answer is that? Keep those kind of replies to the kiddie boards and not here.
The 76cc heads are good depending on the castings. The larger combustion chambers unshroud the valves and it's easier to put bigger valves in them. Since you're going to buy some JE pistons, get some that will bump up the compression with 76cc heads.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
I had a set of pocket ported #882 76cc heads on the last engine I had in my 82 Z28, and was able to get it down to 12.52 @ 108 I had a set of 1.94"int, 1.50" exh Manley Pro-Flo valves, and a set of K-motion 1.25 springs. I used TRW .125" domes, and the compression worked out to be 9.92: 1 after cc'ing the chambers to a true 76cc. I cut them .010" to true them up. The engine was a .060" over 2 bolt 350, the above mentioned heads and pistons, a Ultradyne solid cam, Performer RPM intake, BG 650 Sport Claw carb, and a set of Hedman 1 5/8 shortys w/ Y pipe. It had a TH350 w/ 4000 ACC stall, and 4.10 Richmonds. When I originally built the engine I drove the car all the time, and I the Edelbrock RPM camshaft in it before I put in the Ultradyne solid. It also had a B&M 2400 Holeshot convertor and 3.42 gears. I was able to get 13.20's at 102 out of that set-up, so to say 76cc heads won't run well is inaccurate.
82 Z28 383, Ported 215cc Dart Iron Eagle Heads 72 cc Comb. Chambers, Comp custom grind Hyd roller cam, Speed Pro .250" domes, Wheeler Motorsports 4340 I beam rods, Eagle 5140 steel crank, Weiand Team G intake, Holley 830 DP, hedman headers
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET:11.60 @ 114.56, w/ a 7.34 1/8 @ 93.50, and a 1.622 60'
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
Bassett Racing
Bassett Racing
Car: 88 Firebird WS6
It would still be better to run flat-tops and 64cc chambers even though the cr works out the same. 76cc chambers are great for 383 and 400's though.
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
'88 Camaro RS 2.8L
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
