tpi harness question
Old Mar 1, 2005 | 02:22 AM
EatFordShtDodge's Avatar
Car: C230 Kompressor
Engine: 2.3L Supercharged I-4
Transmission: 5-Spd Tiptronic
im swapping my carb for a tpi and my car is a T-5, the donor car is an auto. is it possible to use a tpi harness from the automatic on my t5.
Old Mar 1, 2005 | 08:50 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: tpi harness question
Yes, the only mod you'll have to do is wire the backup lights.
You'll also want to get an electric speedo, and wire that to the ECM, and use a manual prom.
-- Joe
Old Mar 1, 2005 | 03:29 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Worked for me.......Only thing i remember there was an issue w/ the VSS .
Old Apr 14, 2005 | 02:55 PM
Re: Re: tpi harness question
-- Joe
alright, cool. my next question is what options do i have as far as proms. can i get just ANY manual prom? im goin to guess it has to be at the very least a V8 prom... but other then that....
Old Apr 14, 2005 | 03:14 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
It needs to be a prom that was originally from the same displacement engine, even if you reprogram it.
Old Apr 14, 2005 | 03:17 PM
alright so it has to be a 5.0L prom. does it matter if its from a carbed car or not?
Old Apr 16, 2005 | 06:06 AM
bump
Old Apr 16, 2005 | 11:42 AM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
If you are running a 165 ecm(used on 86-89 F bodies), it has to be out of a 165 ecm. Same thing goes if you are using a 730 (used on 90-92 F bodies). They will not interchange. Depending on the year prom you use, you may need to disable VATS or make a couple of tweaks to make things right, but its not a difficult thing to do.
The carbed cars never used either of those ecms, so no, it will not interchange.
Caspar
Jun 19, 2016 11:19 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
