MSD ignition
Old Mar 17, 2005 | 10:39 PM
Coult_91's Avatar
Car: 91firebird, 2000 camaro
Engine: 305 tbi,K&N, edelbrock intake & 3.8
MSD ignition
I was looking at MSD ignitions and i was wonedering which one would be best for my LO3?
Old Mar 18, 2005 | 09:14 AM
IROC-Z28_CAMARO's Avatar
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
I would go with the MSD 6AL box, Super conductor wires, and a high output coil.
Old Mar 18, 2005 | 09:58 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Save your money and put it into another mod. I would look into a set of aftermarket wires though.
Old Mar 18, 2005 | 12:03 PM
Coult_91's Avatar
Well this isnt the only mod i am doin this summer (when money starts rolling in) i am getting some tpi heads port and polished,cam, hooker headers, and pretty much whole new exhuast. and i ve heard good things about this one. so i figure it couldnt hurt.
Old Mar 18, 2005 | 12:22 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You have a great list of mods there but it still won't be needed. I would take that money and put it into chip burning stuff. There is nothing wrong with getting a MSD, coil, cap, rotor, and wires but there is no need for the digital box yet.
Old Mar 18, 2005 | 02:01 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
MSD boxes are great for a stand alone IGN system or when you need rev controll but just slaping a 6A or 6AL box piggy backed into your stock system will do nothing noticable. Do all the rest of those mods first then if you have extra cash to blow then worry about a MSD box.
Old Mar 18, 2005 | 02:28 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I'll have to disagree with the crowd. An msd 5, or 6A would likely get you increased gas milage. I've installed about 50 of these (mainly 6A and 6ALs) on cars I got to see a lot of after and the only car that didn't get better gas milage was the Cobra. If you plan on running the car later in it's life the 6A or 6AL would be my choice, depending on your driving skill and equipment.
Old Mar 18, 2005 | 04:41 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
I have to agree with red devil. An MSD 6 or 6A will not only make for better gas milage, it will help for quicker starts and smoother idle. The digital 6, though a bit pricey has a start retard and a single retard control. Even if you're not into nitrous, the retard may be good even if your engine temp is running a bit higher than normal.
I also recommend the blaster coil. It's inexpensive and once you actually have a powerband above 5k, you will notice a difference.
Old Mar 21, 2005 | 04:46 PM
Coult_91's Avatar
chip burning
Well i think i am still gonna get one, but how would i do chip burning i heard not to buy them, that you need to make your own chips how would i do this?
Old Mar 21, 2005 | 04:53 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
get a mallory ignition, its way better, digital, higher primary voltage and its cheaper!
Old Mar 21, 2005 | 06:30 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Re: chip burning
Take a look at the stickies in the DIY PROM board as well as in the TBI board. There is a lot of reading to do before you get started.
What makes you so sure?
Old Mar 21, 2005 | 08:56 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
if your gonna quote me, quote the whole damn sentence, then you will answer your own question why im 'sure' .
Old Mar 21, 2005 | 09:16 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Easy killer. I was asking a question. Most aftemarket boxes are digital and all claim to have the highest output juice. I would worry more about reliabilty than which one produces 5 more volts. I was trying to get you to elaborate on such a blanket response.
Old Mar 21, 2005 | 10:48 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
sry i was alittle tense atm, but the msd are analog. and the primary voltage of the mallory is 520 compared to msd's 460 or 480volts.
Old Mar 23, 2005 | 11:44 AM
Coult_91's Avatar
He got a point
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
meeklay812
Oct 1, 2015 03:46 PM
RedLeader289
Sep 23, 2015 06:50 AM
