CC306 vs GM/Crane '847 w/ ZZ4
Old Mar 19, 2005 | 05:45 PM
SloNlo350's Avatar
Car: 2005 GTO
Engine: LS2
I have a ZZ4 and Stealth Ram in my truck and need just a tad bit more powa'. I want a cam, and was debating between the CC306 and 847. I know that these are both alot of cam for the stock aluminum L98's heads that come on the motor, but they won't be staying for long. A friend of mine keeps telling me to get a CC306, but on another board they are telling me its an old outdated lobe design, and I'd be happier with an 847. I also contemplated the 846, just to be a bit easier to handle, but then I don't want to regret going too small when i get heads. So my question is, will the 847 put the power out of reach with my stock heads? Like I said, I have a StealthRam and a 3000 stall so I am prepared to go to 6000 when I get heads (also swapping the 3.73's for 4.10's soon... I have 28 inch slicks, so I need alot of gear).
Old Mar 20, 2005 | 03:02 AM
SloNlo350's Avatar
Car: 2005 GTO
Engine: LS2
c'mon... no love at all? Someone's gotta have some input!!
Old Mar 20, 2005 | 04:30 AM
12secformula's Avatar
Car: 94 Z-28
OK, well I believe that the GM847 is to big for the Stock heads, but thats just my opinion. The CC306 will work well w/out a doubt, but as you were informed it is an old cam design and there are better ones out there. I have always pressed the fact that it is not the cam size, its the design and how it works w/ everything else. Essentially I am talking about your combination of parts. For not much more than the price of those cams you could have a Custom cam made specifically for your combo....it will match perfectly. Also I think that your L98's could be worked over a good bit and you could also gain a good bit by doing that. Porting and some larger valves can go a long way for performance. What cam do you have now?
Old Mar 20, 2005 | 09:10 AM
SloNlo350's Avatar
Car: 2005 GTO
Engine: LS2
Its a stock ZZ4, as in the whole motor (therefore the ZZ4 cam). As I said, I'm not keeping these heads on the motor for long, so I'm not gonna put $1000 into them when I could buy much better heads. But at this point I am really considering the 306 because, again, I want it to make good power when I get some AFR's but I also don't want to go so big that it hurts me right now.
Any off the shelf cam suggestions that will be decent now and good with heads?
Old Apr 7, 2005 | 09:58 PM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
What exactly is a CC306 cam? And where can I go to check out the specs?
Thanks,
Jason
Old Apr 7, 2005 | 11:24 PM
11 Flat's Avatar
Thanks,
Jason
Intake Exhaust
Gross Valve Lift 0.51 0.54
Duration At 0.006 Tappet Lift 290 307
Valve Timing At 0.006
Open Close
Intake 37 73
Exhaust 90 37
These Specs Are For The Cam Installed At 108 Intake CL
Intake Exhaust
Duration At 0.05 230 244
Lobe Lift 0.34 0.36
Lobe Separation 112
Old Apr 8, 2005 | 12:00 AM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
Is this a comp cam for flat tappets or what?
Old Apr 8, 2005 | 09:41 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Hydraulic roller cam for the sbc. It is a comp cam under the Nitrous HP section I believe.
Old Apr 8, 2005 | 09:57 AM
Tibo's Avatar
Car: 1991 Z28 Vert
For futher reference:
Here are the 3 GM cams:
12370845 Hydraulic roller design I:214 E:224 I:488" E:509" 112
12370846 Hydraulic roller design I:222 E:230 I:509" E:528" 112
12370847 Hydraulic roller design I:234 E:242 I:539" E:558 112
Old Apr 8, 2005 | 11:47 AM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
So this is a nitrous cam. I guess that means that it wouldn't work NA.
So these cams are for 87 and later blocks?
What would be comparable for a GEN I block? Is that what the GM part numbers are for?
Jason
Old Apr 9, 2005 | 09:08 PM
Tibo's Avatar
Car: 1991 Z28 Vert
They call it a Nitrous cam because it has a much longer exhaust valve duration. It will work fine on regular NA cars. Many people have proven this.
Old Apr 9, 2005 | 09:15 PM
Tibo's Avatar
Car: 1991 Z28 Vert
good reading:
https://www.thirdgen.org/techbb2/sho...=hot+cam+cc306
Old Apr 10, 2005 | 10:36 PM
SloNlo350's Avatar
Car: 2005 GTO
Engine: LS2
Yeah, I decided that the '847 was way too big after a little research and I decided on the '846. Its cheap, the power band is right, and it will be even better after I get some heads. Thanks for the help.
KFK
Feb 8, 2009 09:54 AM
dhirocz
Nov 18, 2003 12:00 AM
Spdfrk1990
Aug 2, 2003 07:42 AM
Spdfrk1990
Jul 30, 2003 06:15 AM
poorboy8
Nov 21, 2002 12:07 PM
