350 RAMJET to 400hp?
Old Mar 20, 2005 | 05:27 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
Is it possible to get a 350 Ramjet to push 400HP to the wheels?
Old Mar 20, 2005 | 05:35 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Yes, port the heads and replace the camshaft. The stock ramjet cam is quite small. Something like the LT4 hot cam would be cool. May have to remap the fuel calibration to account for the extra airflow.
The compression ratio could be raised too.
The basic design of the ramjet has lots of performance potential.
Old Mar 20, 2005 | 07:21 PM
crrllmich's Avatar
Engine: L03, LS1
This seems like a dumb question but about how much will a shop charge me to port the heads. I have never had it done before.
Old Mar 20, 2005 | 07:26 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Port jobs can vary from $500 to $2000 depending on what you get and how good the shop is. Expect to pay a good amount for a properly ported set. You should research what changes need to be mae to the Ram Jet ECM to handle a cam swap. I know GM makes a reprogramable closed loop engine management system for the ram jet. The open loop version to my knowledge is non programable and in turn will not run right with a cam swap. If you are planning on buying this motor there is already a Ram Jet 430 that is available. They use GM fast burn heads and a hot cam. It retails for about $1500 or so more than the 350 crate.
Old Mar 20, 2005 | 07:32 PM
crrllmich's Avatar
Engine: L03, LS1
I can't seem to locate a Ramjet 430. Any ideas where I can get one?
Old Mar 20, 2005 | 07:38 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I was trying to dig up an od link that i had but I cannot seem to find it. I did a few searches on google and came up with nothing as well. I know it exists because I had a link and GM high tech performance talks about it every now and then. You may just want to search for the ECM conversion (EFI 4 er something) which will allows you to run and heads and cam combo that you wish.
Old Mar 20, 2005 | 07:43 PM
crrllmich's Avatar
Engine: L03, LS1
Good *** can't find that either.... maybe I am cursed.. lol
Old Mar 20, 2005 | 07:48 PM
Section162's Avatar
Car: '90 Formula
Engine: L98 --> Ramjet
Check this out:
http://www.goautocenter.com/350%20ram%20jet.htm
Old Mar 20, 2005 | 07:52 PM
crrllmich's Avatar
Engine: L03, LS1
Well theres the damn proof it exist lol now where can I buy it. I mean whats better then a plug and play 430HP....but hey they discontinued the camaro and firebird right so...
Old Mar 21, 2005 | 09:51 AM
crrllmich's Avatar
Engine: L03, LS1
Ok I am just gonna port the heads and go with the hot cam but where do I get this ECM controller?
Old Mar 21, 2005 | 10:07 AM
crrllmich's Avatar
Engine: L03, LS1
Is this it?
http://www.azspeed-marine.com/rao2sekit.html
Old Mar 21, 2005 | 11:29 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
You probably could also just use a tpi ecm and harness. It has plenty of functionality and should work quite well when tuned.
FYI, that link just looks like a closed loop kit. An ECM will have this built in for free.
Old Mar 21, 2005 | 06:55 PM
F-BIRD'88's Avatar
The Ramjet ecm can be reprogramed but first it has to be "unlocked" There is a software "key" code that unlocks the chip in the factory MPFI3 Ramjet controller. I don't know what it is.
You don't need a shop to port vortec heads.
You can do it yourself. They do not need extensive porting or any trick technique to get decent usable flow.
there is a good article in Car Craft on how to do these heads.
It is straight forward stuff. I did essentually the same things as discribed in the article and got very simular flow results on a flow bench. You can too.
I would disassemble and hand port the heads , they will need machining preperation for a new hi perf hyd roller cam and valvetrain anyways. I would shave the heads a little and use a thin head gasket to get the compression ratio up a bit higher. I would port match the ramjet intake manifold to match the heads.
I'd get a new hydraulic cam and matching kit Look for a .050" duration of 218 to 240 and .500" to .575" lift
ground on EFI friendly 112-114 LSA. the ecm will still need tuning.
Old Mar 21, 2005 | 11:17 PM
crrllmich's Avatar
Engine: L03, LS1
The new ones come with the MEFI4. How would I hook a TPI ECU to the ramjet, I thought the ECU is built into the intake? I am not being a smart *** I am serious.
Old Mar 22, 2005 | 05:06 PM
F-BIRD'88's Avatar
No its not "built in to the intake"
It sits on the intake. Yes you could use a TPI computer to work with a Ramjet motor. Or use some other aftermarket efi like the FAST system.
TX-SleeperC5
Feb 24, 2016 01:34 PM
89fast5oh
Sep 8, 2015 09:55 AM
john204481
Sep 7, 2015 03:22 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
