stupid question
Old Mar 28, 2005 | 11:44 PM
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
stupid question
i have an older model 350 in my camaro and a stock radiator. the outlet on the water pump is way bigger that the inlet on the bottom of radiator. where can i find a hose that will fit? do they sell hoses that are bigger on one end? sorry for such a stupid question.
Old Mar 29, 2005 | 12:50 AM
VILeninDM's Avatar
yonk the hose you have in the car right now and take it with you to parts store. See what they say.
Old Mar 29, 2005 | 12:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Why not just get a water pump that fits?
Old Mar 29, 2005 | 06:44 PM
bubbz89's Avatar
Car: 1990 RS
because it came new with the motor, do they makes hoses that will work?
Old Mar 29, 2005 | 11:17 PM
five7kid's Avatar
Much, much simplier to just get a new water pump for your car application. Sell the "new" pump that came with the motor on eBay.
Old Mar 29, 2005 | 11:19 PM
five7kid's Avatar
Are you retaining the serpentine system that came in your car? If so, you need a different water pump, anyway.
Old Mar 30, 2005 | 04:54 PM
bubbz89's Avatar
Car: 1990 RS
i am using a v belt setup. just wondering if i could get hoses that would work.
Old Mar 30, 2005 | 06:02 PM
five7kid's Avatar
Most likely you'll be able to cobble something together. Take the existing hose to the store along with knowing the inlet size on the pump. You might get lucky. The universal, corrugated, bendable type is the most likely to fit the bill. Then, the next time you need to replace the hose, you'll have to either remember the number you got this time, or go through the process all over again.
Or, spend $15-$35 now on a water pump that fits the engine, has a hose that is off-the-shelf, is molded to shape, can be looked up by even the least of parts counter types (or, like I do, on the internet), and actually "fits".
Old Mar 30, 2005 | 06:04 PM
bubbz89's Avatar
Car: 1990 RS
would a stock 3rd gen pump work? i though they spun backwards.
Old Mar 30, 2005 | 06:17 PM
five7kid's Avatar
'82-'87 were standard rotation. '88 was the start of the serpentine-type reverse (opposite of engine direction) rotation.
Any particular reason you're not retaining the serpentine set-up? IMHO, it's highly superior.
(I checked www.partsamerica.com - the lower radiator hose is the same for '88 V8 and '86 V8.)
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
It should work. What acc. brackets do you have? Are they from an F-body? The vette pumps are different. All small block pumps of the 350 eara is the long type. Vega and vette are the only exceptions.
Old Mar 30, 2005 | 06:27 PM
bubbz89's Avatar
Car: 1990 RS
so a stock 86 wp has the small hose. cool, that will save me a big headache. thanks guys. the only acc. i am running is an alt. this is mainly a drag car with a little street use. thanks again
Old Mar 30, 2005 | 06:42 PM
five7kid's Avatar
It's nice to know these little tidbits up front. In that case, I'd definately recommend the '86-'87 style (may have also been on '85's, don't recall off the top of my head) multigroove flat belt - looks like a serpentine that is routed like a v-belt. Pretty hard to throw or twist one of those guys.
Old Mar 31, 2005 | 04:25 PM
bubbz89's Avatar
Car: 1990 RS
will my v belt pulleys bolt up to an 86 style wp?
Cleotiz
Jan 6, 2018 08:56 PM
3.8TransAM
Sep 3, 2015 06:38 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
