3.0" crank w/ 6.0" rods
Old Apr 2, 2005 | 07:38 AM
91rs5.0's Avatar
Car: 91 RS (Black, T-top)
Engine: 5.0
Transmission: 5-speed
will a 3.0" crank work with 6.0" rods. the original rods are 5.94"... is there anyway to make it work with 6.0" rods? or is .06 too much of a difference?
Old Apr 2, 2005 | 09:42 AM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Out of curiousity, what kind of engine are you talking about?
Old Apr 2, 2005 | 10:13 AM
91rs5.0's Avatar
Engine: 5.0
350. the crank is out of a 4.3 caprice.
Old Apr 2, 2005 | 10:38 AM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Im assuming that the 5.94" rods are from the Caprice too? And you are planning on using 6" rods instead? Assuming the 4.3 crank has the same journal size as the rods, they should work; the piston/deck "height" is what will offset any changes in stroke or rod length. It seems to me that a 302in.^3 piston for a 6" rod would work. I would definitely mock up the assembly and check/modify the deck height though.
Old Apr 2, 2005 | 11:03 AM
91rs5.0's Avatar
Engine: 5.0
ok. then i'll just get the 5.94 connecting rods from the caprice too. the standard 4.030 pistons will work with those rods i assume.
Old Apr 2, 2005 | 09:41 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Isn't the 4.3L a V6 motor?
Old Apr 2, 2005 | 09:55 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Depends what you mean by "standard" but probably not. A regular 3.48" stroke 350 piston probably will not work properly with a 3" stroke crank without taking half an inch off the deck height.
Old Apr 3, 2005 | 08:10 AM
91rs5.0's Avatar
Engine: 5.0
no. i'm talking about the 4.3l v8 (baby lt1) out of a caprice.
Old Apr 3, 2005 | 08:12 AM
91rs5.0's Avatar
Engine: 5.0
wow, im starting to get a headache. so the 6" rods won't work without different pistons, and the 5.94 will still need different pistons. is there manufacturer that makes these pistons for 3" stroke? thanks
Old Apr 3, 2005 | 08:22 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i believe that aftermarket companies will make pistons for the 6" rod, but your gonna have to call the piston maker of your choice to see what's available for your application.
Old Apr 3, 2005 | 10:25 AM
wildman923's Avatar
Call your local machine shop and have them price out the pistons. Just tell them your building a 302 thats .030 over.
BOB
Old Apr 3, 2005 | 10:49 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The 5.94" rods will not need different pistons, unless the 265 v8s pistons are still attached. Any piston for a standard 5.7" rod with a 3.48" stroke will work fine. The reason is the compression height is the same on both a regular 350 piston and the baby LT1 4.3. If you take 1/2 the stroke, add the rod length the two lengths will be the same. 3.0/2= 1.5+5.94=7.44 then 3.48/2=1.74+5.7=7.44. Then you add in your compression height and how deep the piston is in the whole and they will be in the exact same place. It is the cheap way to build a 302, although I hope you have a 1 piece rear seal block. I helped build a 267 out of a 305 block , 4.3 crank and those 5.94"rods. the same way and the stock 305 piston worked just fine in this case.
Old Apr 3, 2005 | 11:44 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
i take it your building a 302?
you HAVE to use the crank and rods from teh L99 engine (caprice 265 v8) with pistons for a 350 sbc w/ 5.7" rod.
heres how it works
the 350 has a 3.48 stroke, thats .24" longer at TDC then a 3.00 crank assuming both are using the same rods and pistons. so that means the piston wont hit TDC with a 3.0 crank and 5.7" rods UNLESS! and this works out perfect, you increase the rod length to 5.94", i think GM did this on purpose.
3.00" stroke
5.94" rod
350 pistons for 5.7" rod
it works out perfect. good luck with your build, i am going to be putting togther one of these in the future.
Old Apr 3, 2005 | 08:50 PM
91rs5.0's Avatar
Engine: 5.0
yea thats what i meant by standard pistons, standard 5.7 rod pistons that originally sit in the 350.
so how did the 305 react to the decrease in stroke? was it a lot more rev friendly?
Old Apr 4, 2005 | 05:07 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Just to warn you ahead of time, you are going to need either special light weight pistons or pay to have Malory metal added to the crank in order to balance the rotating assembly.
The 3.75" bore pistons from a 265 V8 will be considerably lighter than 4.030" standard replacement pistons. So be ready to pay for either one of those two things.
You may find the "uniqueness" quickly wears off once the $$$ runs thin.
Old Apr 4, 2005 | 10:55 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Does the 4.3 V8 (baby LT1) have a 3.00 inch stroke, or a 3.10?
Old Apr 4, 2005 | 01:34 PM
91rs5.0's Avatar
Engine: 5.0
well, i already have the crankshaft, might as well make use of it. and the rods will cost me $10 a piece.
Old Apr 4, 2005 | 01:38 PM
91rs5.0's Avatar
Engine: 5.0
3.00, 3.10 is 283 i think.
Old Apr 4, 2005 | 01:39 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
A 350 crank core will cost you about $50.
$50 = 30-50 HP
That's likely to be somewhere between $1.00 and $1.60 per HP, depending on how you build the rest of the motor. Maybe even less than $1/HP, if you build a REALLY REALLY hot one.
That's the cheapest HP money can buy, BY FAR.
The decision to use that "free" crank won't look so good when you put it together and it's gutless and your "uniqueness" gets totally smoked by people with the same money or less in their stuff, and you realize that you just spent $2000 or whatever, on building this gutless motor; and the only way to fix it is to go buy that $50 core, and THEN re-spend about half of that $2000 all over again.
Think "big picture" instead of "cheapest I can get by with".
Old Apr 4, 2005 | 01:56 PM
91rs5.0's Avatar
Engine: 5.0
$50 = 30-50 HP
since when are 302s "gutless"? yea i know i can get a 350 crank cheap, but I want to try this out. I already have an lt1 thats goin into my car this month. and if thats still "gutless", it will be a 396 by this summer .
Old Apr 4, 2005 | 02:04 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I know what they're like, because I've had a 302 before. Probably before you were a gleam in your mama's eye; maybe even before she was a gleam in your grandma's eye. Built it just about like somebody with this "rev it to the moon" bit would do it; HUGE solid cam, big heads, 4-speed, the whole schmear. Yeah it screamed.... once I got it past 35 mh in 1st gear. Problem is, it took about 12 seconds to get to 35 mph. I got my a$$ handed to me by B210s and CVCCs and Pintos at stop lights.
Some things are so obvious they're easy to overlook. Which in this case is, more inches = more power if all else is equal. You can outsmart yourself all the way around this one, but in the end, it'll still be true.
All I'm trying to do, is to save you from turning your wallet upside-down over a bonfire.
Old Apr 4, 2005 | 03:00 PM
ede's Avatar
ede
not sure but isn't the big end of the 4.3 rods, or the 5.94" rods differant size than all the other SBCs, 400 excluded?
Old Apr 4, 2005 | 03:34 PM
91rs5.0's Avatar
Engine: 5.0
chill... i don't want your history lesson. thanks for trying to save me money. when i need help with that i'll call geico.
Old Apr 4, 2005 | 05:13 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
And here I thought you wanted to hear some reality; instead, all you want is for some other inexperienced impressionable youngster to come along and help you ooooh and aaaaah over your idea. You're the type that's easily distracted by shiny things I guess. But that's OK, you can spend your money any way you like, it's none of my business. Heaven forbid that you should take advantage of someone else's knowledge they acquired the hard way, and would prefer to make all the mistakes yourself rather than listen to someone that's already made a few of them share how to avoid them. Not that there's anything wrong with that; doesn't affect me one way or the other; after all it's your money; it's just ..... well, stupid.
I hope you like tail lights, because you're going to be seeing alot of them soon. With an empty wallet. You won't even be able to buy a look at the front of another car in your rear-view mirror.
Old Apr 4, 2005 | 05:33 PM
91rs5.0's Avatar
Engine: 5.0
with an lt1 i doubt i'll be seeing many tail lights. the 302 is just so i'll have something to put in the car when i decide to build up the lt1. but i agree with you, the bigger motor will make more power, all other things being equal.
Old Apr 4, 2005 | 06:37 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
The 302 isn't anything special, and by todays standards, rather worthless- but that's history you don't want to hear.
A stock (apparently) LT1 sin't all that special either, don't bother cleaning your rear view mirror.
If you are as thick with regard to suspension advice as you are with motor advice, it won't matter what you have in the engine bay, you won't be going anywhere quickly.
Old Apr 4, 2005 | 06:59 PM
91rs5.0's Avatar
Engine: 5.0
I don't know you, and you don't know me, yet your first reply is an insult. I already don't like your smell.
stock lt1 will run low 13s in a 3000 pound f-body rather easily that may not be track respectable, but its street respectable.
Old Apr 4, 2005 | 07:25 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
You didn't know RB either but had no problem acting like an *** to him.
Last I checked thirdgens didn't weigh ≤3000lbs.... unless your s/n was ODB.
Stock LT1s run low 13's? Define -low- 13's.
Didn't the '95 'vette with an LT1 pull something along the lines of 13.7?
With a curb weight of over 3300 lbs.?
The LT4’s on the other hand dipped into the 12’s
Is that your idea of a 3300 lb. ‘f-body’ in the low 13's??
And it all depends on -whose- street. Particularly since that oh-so-mighty LT1 was replaced with more powerful engines. A 13 second car was respectable around here back in 1991… but wait… that would be history to you huh?
Old Apr 4, 2005 | 07:56 PM
91rs5.0's Avatar
Engine: 5.0
if rb took that offensively, sorry, i didn't mean any offense by it.
my car weighs 3029 pounds. and I will do more weight reduction on it after I put the lt1 in, but it doesn't matter because I won't be keeping the lt1 stock.
Old Apr 5, 2005 | 10:45 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
For the sake of the technical content within this thread, I took the liberty to edit out the non-technical, rules-violating comments.
For the sake of your TGO status, I'd suggest you all keep it technical and not attempt to stroke your cyber-egos.
Old Apr 6, 2005 | 10:26 AM
AJ_92RS's Avatar
Or in this case, de-stroke them.
What would be cool would be to put this aftermentioned 302 into a Vega/Monza or the like. THAT would make for a fun car. Put a fart can and bookshelf on it and fool all the Jap Happies into thinking you've got an "old POS 4 cyl." domestic econobox.
But unless you can get an f-body well into the sub 3,000 lb. range I wouldn't bother. You don't really think that GM built the 302 for the Z28 because they wanted to, do you?
Nervous2
Oct 8, 2015 10:53 PM
skinny z
Oct 5, 2015 06:23 PM
john204481
Sep 7, 2015 03:22 PM
gixxer92
Sep 1, 2015 04:32 PM
