crank keys? why some straight and some offset?
Old Apr 12, 2005 | 09:02 PM
drex's Avatar
Car: 87 formula and 85 olds delta 88 2 d
Engine: 60's 350 holley carb and intake
Transmission: muncie 4 speed with centerforce
Axle/Gears: 3.42 99 camaro rear w/ discs
i noticed on my motor it had a kinda offset key that held the balancer on the crank a little off? why are they used and wont it throw off timing? should i stick with it or put a normal straight key in? also which way are the offset keys supposed to face? infront or behind? just curious anyone know? thanks guys id be lost without thirdgen
Old Apr 13, 2005 | 05:11 AM
ede's Avatar
ede
could be halfway sheared instead of offset, i'd replace it with a new key. if it is indeeed offset it could face either way depending on where you wanted the set the timing.
Old Apr 13, 2005 | 07:39 AM
drex's Avatar
n its not sheered the key was just indexed a click over to one side...both keyways on the balancer and crank were snug... ill put a straight one on..
Old Apr 13, 2005 | 09:54 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Doesn't the balancer bottom out (become fully seated) when it hits the crank timing gear?? If so, I can't see this offset key working (since the balancer would hit the crank timing gear key wrong)... There is no point to it obviously in the first place, since if you want to change your timing, just change it, no need for tricks..
Old Apr 13, 2005 | 09:59 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Think 'timing' in terms of advancing and retarding the cam.
Old Apr 13, 2005 | 10:59 AM
drex's Avatar
with the key im talking about the balancer still tightens all the way till it bottoms out but the channel in the balancer and the channel in the crank nub arent perfectly even... so it would advance or retard the cam and not the ignition timing???? i think it would just throw your timing mark off?? im just trying to figure out what its purpose is.
Old Apr 13, 2005 | 11:07 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
"Indexed" = partially sheared
It isn't intentional, and didn't come that way
It's garbage
Throw it away and install an undamaged one
Old Apr 13, 2005 | 11:09 AM
drex's Avatar
the key is definitely not sheared... it has no damage at all... it has to have a purpose but you just dont know...it looks identicle to a flat key but has a step in it.....
Old Apr 13, 2005 | 11:47 AM
Damon's Avatar
Offsetting just the balancer would only affect the TDC mark of the balancer lining up correctly with the timing tab/pointer on the timing chain cover. In theory, you might be setting your ignition timing against something other than true TDC (or maybe they put the offset key in to correct a balancer that wasn't showing true TDC with a regular key).
Old Apr 13, 2005 | 12:14 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The key is sheared.
There is no purpose.
It is trashed.
Throw it away and get an undamaged one.
Old Apr 13, 2005 | 12:34 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
someone probably replaced with whatever they had lying around. offset woodruff keys exist, usually used for cam phasing, simply searching on 'offset woodruff keys' will give you alot of info on the internet.
they are usually used to advance or retard cams which don't have the capability in the timing set--older engines, and were used before the adjustable timing sets became available.
now, its probably mistakenly installed. so just remove it and put in a standard key.
good luck!
Old Apr 13, 2005 | 01:11 PM
drex's Avatar
thank you very much for the explination....gained a brain wrinkle!! i will replace it with a standard key...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
383cam
Sep 9, 2015 06:01 AM
Gunsbee
Sep 7, 2015 07:10 PM
tgp1990
Sep 4, 2015 06:24 AM
Formula_88AE
Sep 3, 2015 01:47 PM
