TPS Voltage to high or just right? Weird idle prob.
Old Jul 31, 2001 | 11:38 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Well on a friends 91 Z 305 TPI (if ya can call these mods it had K&Ns, a flowmaster muffler,and a TB coolant bypass. thats it everything else is stock) the TPS voltage is set to at .58-.59 volts at closed trottle at WOT it is at 4.35 volts.
What happens is that when ya come to a stop the rpms drop to about 500 then kick up too about 700 then steadys itself out about 600 rpm.. Also too this doesnt happen everytime ya stop.. Just randomly.. Like it wont do it for a day or 2 then it will do it very time ya stop then it would do it 3 outta 10 times ya stop.. Oh yeah and it seems todo this when the car is warmed up to operating temp too. Wither it be just coming off the highway or in ciity driving.
Ive been trying to figure out the idle prob on it for quite sometime now. So far everything checks out to be in great working order. The car has a new IAC, new plugs, spark plug wires ohmed out fine, good amount of spark, the pick up in the dist is fine, module is fine, fuel pump is fine (ran 2 15.3's at the track with it this past saturday at VIR) and I think that is everything.
Only thing that I havent checked is that MAP sensor, the CTS (the fans work fine so I assume that the CTS is fine) and the MAT (or IAT)
Any other ideas would be great cause this has me stumped.
Kat
[This message has been edited by Kat (edited July 31, 2001).]
Old Jul 31, 2001 | 11:48 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Oh yeah and there isnt any vaccum leaks.. Even tho the hoses look kinda eeehhh, they need to be replaced but I know that isnt the prob.
Kat
Old Aug 1, 2001 | 07:11 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
btt
Kat
Old Aug 1, 2001 | 07:19 AM
KeithO's Avatar
For what it's worth...
I just checked my TPS voltage on Sunday and got basically the same readings... Those numbers look normal to me.
Old Aug 1, 2001 | 09:58 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Hey Kat, might be time to pull the TB and clean it all out, as well as the IAC passages. TB gasket kit is about 10 bucks.
Old Aug 1, 2001 | 10:44 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Mike I did do that when I replaced the IAC
Kat
Old Aug 1, 2001 | 11:24 AM
manuel's Avatar
I am having problems with my IAC valve.I can't get it to idle right. I have gone thru 2 new IAC valves and still doesn't idle correct.IT gets fine until the coolent gets to 220 and the fan starts.but when i start it,either cold or hot,it idles crazy,sometimes it dies.
Old Aug 1, 2001 | 11:01 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Manuel did ya set the min idle right?
Kat
Old Aug 2, 2001 | 12:22 PM
alexrela's Avatar
Try wd40 on linkage, both on TB and inside gas pedal
'91 Camaro 3.1 t-tops 44k original.
'98 GMC Sonoma excab 4.3 auto 35k.
Old Aug 2, 2001 | 12:41 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
When you installed the TB Bypass, you affect the way the engine performs it calculations for various things, including the idle.
To stabalize the idle, the IAC is "migrating" to a step count that is vastly different than "initial" IAC Step Counts defined within the eprom. Do you have a non-stock t-stat (ie. not 195*?), if so, you also have caused the IAC Learn to not function as the CTS temp is lower than the minimum for the IAC Learn.
I had a similar problem, and the only way I could fix it was modifying the IAC Step Counts vs Coolant Temperature Table inside the eprom. Then my idle was very stable and would almost instantly go to the Idle Speed Vs Coolant Temp settings, which is ALSO defined inside your eprom.
Old Aug 2, 2001 | 02:15 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Alex it defantly isnt the gas pedal stickin cause I already did that the other day hehe
Glenn I belive the car does have a 180* t-stat in it..
Damn I was hoping that it wasnt in the chip at all..
Well time for me to spend the cash on some prom burning stuff.
Kat
Old Aug 2, 2001 | 02:29 PM
Car: Death Mobile
Engine: 666 c.i.
You didn't mention whether you have relocated MAT, but if you do, that even further compounds things with an SD car.
The good news is that there is a lot of info on SD cars. I have even come up with correction factors for the MAT so you can "optimally" run a relocated MAT on an SD car with a TB Bypass. Now my ECM can accurately use the information on the incoming air temperature to calculate the proper injection pulse widths. Whether my engine is hot or cold, I am not plagued with the "poor performance when you let the hot engine sit about 10 minutes and restart it on a hot day" that my car previously had.
Old Aug 2, 2001 | 04:29 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Nope that MAT isnt relocated, it is still in the bottom of the upper plenium.
Glenn is there anyway that I can get a copy of that .bin file to look at?
Also to do you have ICQ or anything of the sort?
Thanks again
Kat
[This message has been edited by Kat (edited August 02, 2001).]
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
CORV3TT3
Aug 23, 2015 11:26 AM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
