Need help. I have a problem with the rear of my car...
Old Aug 1, 2001 | 10:47 PM
Tommy92RS's Avatar
During 1/2 to full throttle off a red light, I get a bang sound from the pass. rear tire area. This only happens sometimes. I just had an aligment done this morning and the banging started this afternoon. Do they do any adjustments back there or is it my u-joint?
Any suggestions is appreciated. Thanks.
Tommy
Old Aug 1, 2001 | 10:53 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
You said the sound was coming from your passenger rear tire, might want to check to make sure the spare tire is not loose. If it's not the tire, then take it back to where your car had the alignment done.
Old Aug 1, 2001 | 10:57 PM
Tommy92RS's Avatar
Hmm, sounds good. I'll check it out.
Old Aug 1, 2001 | 11:01 PM
speedlvr's Avatar
Maybe it's backfiring.
Old Aug 1, 2001 | 11:07 PM
Tommy92RS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by speedlvr:
Maybe it's backfiring.</font>
Um, no. It's deff mechanical. Like I ran over something big. But I'm not running over anything.
Old Aug 1, 2001 | 11:21 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Check all the rear axle mounting stuff like the panard (spelling?) bar, torque arm, etc. I put a shift kit in my trans, then I always heard that clunk when it shifted. Found out that the crosslink thingy was loose on the axle. Sorry, I'm too tired to think of names of stuff right now.
Good Night ya'll
AJ
Old Aug 1, 2001 | 11:37 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Check the trans mount..sound travels in wierd ways through a floorboard..
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Aug 2, 2001 | 01:31 AM
Tommy92RS's Avatar
OK guys. I can't see under the car b/c it's too dark and I don't feel like ripping covers off at midnight.
BUT, I did take the car out and performed a little experiment. It's the same bang noise as if you throw it in reverse and give it some gas. The wheel hop banging is the EXACT same sound. Does this help???
Old Aug 2, 2001 | 05:53 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Put a tranny mount in it.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Aug 2, 2001 | 10:45 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You could also check the rear right upper shock mount to see if it's busted through; but I'd put my bets on the other suggestions first.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Aug 3, 2001 | 04:55 PM
Tommy92RS's Avatar
Thanks guys for all your help. It was the tranny mount. I installed a polyurethane one now. It now feels different when I push the car into high revs (3,500+). I feel a slight vibration in my *** . Hopefully it'll go away when the mount breaks in a little.
customblackbird
Aug 15, 2021 10:16 PM
IROCZ1989
Aug 19, 2015 08:15 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
