Any oil additives recommended to stop a minor leak.
Old Aug 4, 2001 | 06:55 PM
rondubbs's Avatar
ever since i put the new intake on there is a tiny oil leak, real annoying, im not gonna pull it off again so what do you guys recommend to add to my oil to plug it up? do those additives really work? and will they harm my engine?
thanks
Old Aug 4, 2001 | 07:00 PM
u r sofa king we tah did's Avatar
if i were you i wouldnt put any of those additives in my engine. is it comming from the back where the manifold meets the block? only real good cure for this is to rip it off and put a nice sized bead of grey rtv sealer on the front and back where the manifold touches the block, let it cure a few minutes to where it forms a light skin and then install the manifold as usual
Old Aug 4, 2001 | 07:02 PM
rondubbs's Avatar
tried that once before,, didnt work...
Old Aug 4, 2001 | 07:07 PM
how can that not work, thats how its supposed to be done in the first place
Old Aug 4, 2001 | 07:19 PM
Vader's Avatar
Ron,
Not a flame, but just helping you reason it out. You probably already know the correct answer.
Anything that you can add to oil that will sludge up and seal a gap on the underside of the intake will likely also sludge up and seal the ring lands, pressure relief valve, and any other closer-tolerance engine parts.
Additives that enhance the oil are marginal enough, but those designed to stop oil consumption and leakage are very suspect. I'd save the cash on the oil additives and get a new set of "Walls of China" and RTV.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Aug 4, 2001 | 07:40 PM
JETHROIROC's Avatar
Ron, is it coming from the intake manifold bolts? If so, wouldn't take long to back them out and coat them with teflon thread sealer. Be specific about where the leak is and maybe we can help. You may just have to bite the bullet and pull the intake again. I second Vader about the additives for sure.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, Accel coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley AFPR, ported plenum,
Ruger P95DC, hot wife, new oil filter, thick rubber floormats, no cats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Aug 4, 2001 | 07:52 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Hey Ron, it may be a pain in the nads, but you have done a lot of work to your car, so do it right. Pull it part and do it again right. Listen to these guys, they know what they are talking about.
Good luck man.
later
Mike
(Gran Turismo Americano) "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs
Old Aug 4, 2001 | 07:53 PM
Stuart Moss's Avatar
I agree with "JETHROIROC". IF the leak is coming from one of the manifold bolts, just tightning them (torking to specs?) may solve the problem.
That happened to me. Completely stock 305 TPI '91 that, after ~80K miles, I suddenly noticed a teeny little puddle of oil around the center bolts on both the left and right sides of the manifold. It had been absolutely dry for the previous 80K miles!
I removed the runners, tightned the bolts that were a little loose and it solved the problem. I didn't even coat them with teflon seal - although that's a good idea.
Old Aug 4, 2001 | 08:28 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
If your manifold front or rear seal is leaking, try this trick. Get a few Q-tips and some sealant and swab some sealant over the area where the manifold and block meet. Worked fine for me.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old Aug 4, 2001 | 08:32 PM
rondubbs's Avatar
there is oil on the oil pan,, seems like its dripping from the intake.
this is the crap Edelbrock intake that had casting problems with the injector bolt holes being too low, so im figuring it also has a sealing problem in the rear.. oh well.
Old Aug 4, 2001 | 09:26 PM
JETHROIROC's Avatar
Also check your distributor housing gasket if you're thinking it's from the rear of the engine. Just another easy thing to rule out.
1992 Trans Am
May 10, 2023 07:19 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
bamaboy0323
Aug 15, 2015 07:20 AM
