car dies at stoplight and stop sign
Old Apr 25, 2005 | 11:40 AM
camaro25thrs's Avatar
Car: 87 iroc
I just put on a new intake manifold and now the car runs like crap and and dies at stoplights and stop signs. im please help. The engine is 1992 305 tbi auto.
Old Apr 25, 2005 | 12:11 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Check for serious vacuum leaks, especially around the base of the intake near the runners.
Old Apr 25, 2005 | 12:56 PM
Car: 87 iroc
How would i check that?
Old Apr 25, 2005 | 02:24 PM
ajl'86T/A's Avatar
Car: 1986 T/A
Engine: 5.0 carb
Transmission: 700-R
get sum 1/4 in. rubber hose and listen for a hissing noise at the edges of the manifold
Old Apr 26, 2005 | 09:15 PM
1stTransam's Avatar
Car: 1988 Pontiac Firebird Trans Am & 1992 Pontiac FireBird
Engine: V8 305 TBI & v8 305 TBI
Transmission: 700R4 & 700R4
better off to buy some carb cleaner like (2+2) and spray around the manifold (engine running). if the idle picks up, you found the leak.
Old Apr 26, 2005 | 09:59 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
That carb cleaner method never worked for me.... Maybe propane will work... (use a little bottle of propane, unlit, and "hose down" areas, if idle changes, that's a leaky area...)
How'd you seal the gasket? with RTV? torque down right?
Is your idle higher then normal now?
Old Apr 26, 2005 | 10:10 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Originally posted by Sonix
unlit
yeah, dont overlook that.
I prefer the hose-in-the-ear method. Also works good for exhaust leaks, and telling if you're running rich, but you have to stick it in your nose for that...
Old Apr 27, 2005 | 10:14 PM
Car: 87 iroc
I used fle pro gasket and rtv, I let the car sit for a good day and a half for the rtv to dried. I tried the carb cleaner idea. It didn't work. I was listern to the engine, I think it is coming from the back of the intake. I think it is the distributor gasket, that is the problem. Im going to rtv that up.
Old Apr 27, 2005 | 11:58 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
how about your oxygen sensor?
Old Apr 29, 2005 | 12:38 AM
Car: 87 iroc
It was the distributor gasket, just a little rtv and it was fixed. Oxygen sensor
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
