Hood clearance, 86 TA, Air Gap
Old Apr 25, 2005 | 05:42 PM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Transmission: TH700R4 Raptor
Axle/Gears: 2,7x -> 3.00 or 3.50
I am thinking of replacing my Edelbrock Torker intake, but I have an Edelbrock Performer RPM Air Gap sitting on a shelf in my garage. I have a HO Dual Snorkel aircleaner from a Camaro.
I think the Air Gap is higher than the Torker.
My car is an 86 TA with OEM hood. Will it fit under my hood or cant I use the HO Aircleaner with the Air Gap and OEM Hood?
Thanks, Jon H.
Old Apr 26, 2005 | 09:12 PM
rjmcgee's Avatar
It will fit under the hood of a Camaro with a drop base and 3 inch tall air filter. I have heard that the TA has less room under the hood so I don't know that this helps. Also, an RPM Air Gap is 15/16 ths of an inch taller than a regular Performer intake. Once again, I don't know how your intake compares to that. Another usefull peice of info is that I thought that the drop base filter might be a restriction and it isn't at all. When I dynoed my car a couple weeks ago I removed the air filter on the second run and lost 1 hp, that is with a K&N so I guess they really do help too.
Old Apr 27, 2005 | 01:59 PM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Thanks, I sure hope it will fit because I really like the look of the dual snorkel aircleaner and its alwais better to use cool air than hot.
Nonni
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Dialed_In
Aug 20, 2015 01:45 PM
TreDeClaw
Aug 14, 2015 06:58 PM
bryan623
Aug 10, 2015 11:33 AM
