new engine, high oilpressure.
Old Apr 29, 2005 | 11:32 AM
devilfish's Avatar
Rebuild 350tpi, new crank,rods, pistons,lt1intake.
When cold and idle i got around 75 psi, and when I "blipp" the throttle it goes of the scale and bottom out. When The car is warm It is around 50-60 psi, and when I "blipp" the throttle it goes to 75 psi. The gauge is a bit irratic, bounce around a bit. And when I take of the cabel to the oil-pressure censor the needle bottom out. Bad censor, or bad engine?
THanks
Old Apr 29, 2005 | 03:13 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Put a mechanical gauge on it and see what you get. The one in the dash kinda sucks and is usually inaccurate.
Old Apr 29, 2005 | 03:16 PM
devilfish's Avatar
hmmm ok . Is there someway you can test the censor? When I got ignition ON but engine off, the gauge bottom outs. And some times it just goes to the bottom fast as hell. Then bounce upp again to around 70psi. Strange..
Old Apr 29, 2005 | 03:32 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
It's called the replacement test.
devilfish's Avatar
Yeah to bad Sweden dont have GM spare parts "everywhere", and I must order it...
Old Apr 29, 2005 | 04:02 PM
Car: 88 Camaro SC
Engine: SFI'd 350
You can apply pressure to the sender with compressed air to test it. Compare the readings from a mechanical gauge to whats being displayed on teh dash
Old Apr 29, 2005 | 04:04 PM
devilfish's Avatar
cool thanks for the tips
I heard that when you turn ignition on, the needle should go to zero. And then when you turn on the engine on it should go to the right pressure. Min just goes to max when ignition on.
Old Apr 29, 2005 | 04:15 PM
ede's Avatar
ede
yes there is a way to test the gauge. i use to have a tester made by snap on for doing it, but since it got to be a bit out dated i sold it on ebay.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
