Wierd temps.....what T-stat do I have?
Old Aug 12, 2001 | 09:50 PM
shaocaholica's Avatar
I bought my '91 Z28 about 3 years ago and I never changed the t-stat nor did I examine the current one. After hearing some discussion on t-stats and cooling Im beginnine to think I dont have a stock temp t-stat. Last night it was very humid and cool, about 60-70. I was driving my Z28 around on back streets with no traffic at all at about 30-50 mph. My temp gauge was around 135-155. However, if I had left my car idling at a full stop my temp got to 200 (this took a while). Whats the verdict guys?
Old Aug 12, 2001 | 10:31 PM
Synergy's Avatar
Ummm... why don't you take it out and look at it ?!
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car !
Old Aug 12, 2001 | 11:32 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Why go to all that trouble?
The stock thermostat is 195º, but if its been changed it could be anything, like 160º, or 180º.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Aug 12, 2001 | 11:34 PM
rezinn's Avatar
Go to your local auto parts store and buy a 195 degree thermostat and gasket, then put it under your thermostat housing. After this I can tell you what temp thermostat you have.
Old Aug 13, 2001 | 01:01 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
wow 135-155
man im lucky to get my car under 220 when i am cruising
maybe there is something wrong with my car
lol
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
new best E.T. (dont laugh) 15.986 @84.93mph
old best E.T 15.997@86.04
http://www.geocities.com/K_towngangsta
Old Aug 13, 2001 | 03:20 PM
89firebird's Avatar
Car: 89 Firebird Formula T-Top
Engine: SP383 FIRST Fuel Injection
Transmission: T56 Tremec Magnum
Axle/Gears: Moser 12 Bolt, 3.42 Eaton Posi
Probably no t-stat installed, if it's running that cold.
Old Aug 13, 2001 | 04:01 PM
highhat's Avatar
mine does the same thing it has a 160 thermostat. But I plan on putting in a 180 because it runs to cool.
Blue 1989 IROC Z28
Old Aug 13, 2001 | 06:29 PM
Eddie's Avatar
Most likely a 160* thermo, no big deal except for the fact that your car needs to be setup for this, if stock you need to change it back to the 195*(I did this and my car and it ran better to my amazement). These cars run at a certain temperature for a reason and they are designed for that temp and everything functions at that temp unless you make mods and that is a different story. I had a 160* thermo(not that it helped) and a bad EGR valve and I was getting 27 mpg hwy and 24 mpg cty, I changed the thermo and the EGR valve and now I am back down to 18 mpg hwy but I have better performance.
Old Aug 13, 2001 | 10:59 PM
GeneralGrant's Avatar
im stupid whats an egr?
mud runner
Nov 2, 2015 07:30 PM
lanceflame44
Sep 25, 2015 12:28 PM
andy74
Sep 3, 2015 08:41 AM
Apeiron
Carburetors
Oct 18, 2001 04:54 AM
Stormshadow GTA
Feb 27, 2001 06:43 PM
