LT4 cam question
Old May 7, 2005 | 08:21 AM
fin170703's Avatar
Car: '87 iroc camaro
Engine: 350 L98
Transmission: 700-R4
Axle/Gears: 3.27 posi
LT4 cam question
hi all. quick question. will a LT4 camshaft for a '91 tpi fit in my L48 5.7 350 vette engine. thx
Old May 7, 2005 | 10:16 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Will it fit? Yes. All SBC cam journals are the same size, except for the LS series engines.
But a LT4 cam for a '91 TPI? I'm confused on that one.
Vader's Avatar
First, the LT4 cam was not made for a TPI, but it will fit. It should also fit the older L48, but an original LT4 cam will not have a fuel pump lobe to operate the mechanical pump on an L48. The only other fitment problem is the length of the cam sprocket dowel, which is easy to remedy. You can pull the OEM dowel and replace it with a shorter one, grind the dowel legth to the correct length, or sometimes drive the dowel deeper to achieve the correct length.
Old May 7, 2005 | 10:18 AM
Vader's Avatar
Looks like Illinois just woke up...
Old May 7, 2005 | 11:23 AM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Just get a flat tappet cam, or retrofit roller ..
Old May 7, 2005 | 12:27 PM
fin170703's Avatar
Engine: 350 L98
the guy who is selling it said he originally brought it for his '91 tpi. would you recommend a different cam if so which one. im not looking for mega performance. my mods will be new heads , fairly mild ones to replace the terrible ones on the stock L48, new carb , already fitting ( holley ), headers and staright through exhaust system. so if anyone could recommend a cam that would work well with the above mods it would be great.
oh while im here my tuning guy said that the stock hei distributor are crap. is that true? if so is there a direct replacment
Old May 7, 2005 | 12:54 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
The LT4 and most cams in cars after 86-87 are roller cams along with 91+ trucks are so.
It will not work in your motor without some jury rigging and haching of **** up.
Old May 7, 2005 | 01:43 PM
fin170703's Avatar
Engine: 350 L98
any ideas what would work mate?
Old May 7, 2005 | 03:56 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
A regular flat-tappet cam.
MustangBeater20
Oct 29, 2022 09:20 PM
80s Poncho
Aug 19, 2015 06:45 PM
redmaroz
Aug 16, 2015 11:40 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
