opions on modifying stock 88 camaro rs ???
Old Aug 23, 2001 | 10:25 PM
speedtendancy's Avatar
i just bought my first car(88 camaro rs
T.B.I) whats the first mod i should throw in it.... im thinking a cam with 427"...
preformer "air gap" edelbrock intake......
and a good set of headers........
i just want somethin competetive on the street.......... help me out fellas... thanks
if possible E mail me (speedtendancy@aol.com)... thanks
SPEED
[This message has been edited by speedtendancy (edited August 23, 2001).]
Old Aug 23, 2001 | 10:29 PM
manuel's Avatar
First,make sure that everything is working in good order. I was in the same spot as you.
The TBI engines have a hard time getting them to idle. thats about it. knock on wood.
good luck and tell us on the progress.
Old Aug 23, 2001 | 11:06 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
i'd say go with a set of edelbrock t.e.s. headers and a good cat back like the edelbrock, flowmaster, dynomax, etc. cam is a bit pricey as a starter. you may want to get a decent aftermarket chip for it such as a jet stage 2 or fast chip. maybe a set of pullies, etc. i wouldn't recomend going with the air gap since your stock tbi isn't exactly a bolt on to it without an adapter and your not flowing enough air yet to need it. as i've heard, before you crack the safe work on the combination. simple bolt on's first.
Old Aug 24, 2001 | 03:14 AM
rezinn's Avatar
Welcome to thirdgen.org, Speed.
You should really talk to people on the TBI board to see what kind of cams they are running, I think that if you are going to swap you may as well put something a little more aggressive in. .427 is pretty low lift.
A cam is pricey? I paid 180 dollars for my cam.. my cat back cost $600 and my headers cost $325(ceramic coated edelbrock, thats a damn good deal too).
I would highly reccomend all of the free mods you can find, learn how your car works... Try the TBI board, I've heard of some open air element mod that people see a sotp difference from. A performance tune up would be a good idea too. You can replace most of your ignition with something like MSD, Accel, Mallory, Taylor, etc. Good luck, have fun, and post often!
Old Aug 24, 2001 | 07:08 AM
ede's Avatar
ede
welcome to thirdgen.org. sorry to say there were no RS camaros in 88, the SC had the ground fx starting in 88, in 89 the SC was dropped and the RS became the base model and the IROC was the hot rod.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Aug 24, 2001 | 11:39 AM
Drakar's Avatar
Um unless Im mistaken 88 had RS in Cali, but very rare.
1989 Trans Am GTA, 5.7L TPI, TH700-R4, T-Tops, dual cats, 9-bolt rear, 3.27, Dynomax muffler, K&N
1992 Camaro RS, 5.0L TBI, T-5, T-Tops, 3.08, L69 Dual Snorkel, K&N - Sold
Old Aug 25, 2001 | 02:29 AM
zippy's Avatar
Engine: 5.3L
my posting of the cam being pricey was pointing out that it's an expensive place to start especially when he may be able to run a larger cam later on than he could right now in stock form. the average price for a roller cam is normally well more than 180 bucks and that doesn't include gaskets and timing chain.
Old Aug 25, 2001 | 11:55 AM
ZIPPY:: where can i buy a fast chip,
whats an estimant on the price for one,
are they easy to change??
SPEED
Old Aug 25, 2001 | 01:30 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
It depends: are you planning on keeping the car and eventually putting in a bigger engine? On my car, 91 305 TPI, I went from 15.9 to 14.5 without even touching the engine. I put in a 2500 stall, headers, 3" exhaust, and 3.73 gears. All these parts are compatible with my soon-to-be-installed 350. I just figured that if you plan to keep the car for a while, then your money would be better spent on something other than components for the engine. Of course, a set of 1.6 rockers would help the cam out a little, and you could put them on a 350 if you decide to go that route.
91 Z28
Come see The Vicious...
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Linson
Aug 21, 2015 02:12 PM
ezobens
Aug 19, 2015 10:29 PM
marcusaw
Aug 10, 2015 08:13 AM
