Intake backfire... that you can feel through the gas pedal?
Old Sep 2, 2001 | 01:24 AM
Xenodrgn's Avatar
Ok, I'm having what I think is intake backfire, whenever it happens, it feels like the gas pedal is reaching a hard spot, and then it'll pop and the pedal will be normal... is it intake backfire? It only happens when it's cold, and not all that often, (maybe once or twice a cold start)...
Could it be caused by the fact that I'm running rich (or weak spark) or is it strickly timing?
When I adjusted the timing with a friend (valadictorian of his automotive class, works for BMW and he can't even legally drink yet...) we set it to 10*, stock spec. for my engine (says so on the sticker)... we disconnected the EST, but still got advance... we figured the EST did something else, and didn't think much of it...
Should I go out and turn the distributor clockwise a little more?
Gimme some suggestions please! :-P
1985 Camaro SC - 2.8L, auto.
http://www.xenodrgn.f2s.com/Frontright.jpg
Old Sep 2, 2001 | 01:34 AM
Xenodrgn's Avatar
I should also note that I get 15 MPG... tops... with no mods... so I know it's not lean...
If the timing was way retarded (pun intended), could it cause my plugs to be fouled (soft carbony)? The loss of MPG? Make me think that the O2 is bad?
I'm anxious to hear you answers! I feel like I'm finally on to something...
[This message has been edited by Xenodrgn (edited September 01, 2001).]
Old Sep 2, 2001 | 11:23 PM
Xenodrgn's Avatar
WTF? No answers? I figured this would be an easy one for you all... or perhaps you're all getting sick of my b*tching... :sniff: I see how it is...
Old Sep 2, 2001 | 11:53 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
Well i don't know too much about 2.8FI system or have had a similar problem. First do you get any codes? Second How long ago has a tune up been performed? plugs, rotor, cap, O2 Sensor, etc.... If no codes then look for vacuum leaks around the throttle body bellows. Since your gas mileage is suffering and if no codes present i would change the o2 sensor. worked wonders for me. I'm just trying to help here.
88' IROC-Z, 350 TPI, 700-R4
[This message has been edited by mystikkal_69 (edited September 02, 2001).]
Old Sep 3, 2001 | 04:43 PM
Xenodrgn's Avatar
Tuneup was done about 4 months ago... a few thousand miles... cap, rotor, plugs, O2, intake gaskets, injectors checked, fluids, clean IAC and TB and intake, set timing to 10* (stock)(mark could be off a few degrees?)...
I'll play with the timing a little more, and worst comes to worst I'll spend my paycheck on getting the O2 cut out and a new Bosch one welded in... (threads stripped) (as well as new cap/rotor, and plugs...).
Old Sep 3, 2001 | 10:27 PM
Car: 1988 IROC-Z
how many miles on the engine? a far off possiblity could be a loose timing chain. have you tried running the engine with the timing a little more advanced base timing than stock...say 5*? or more. does it still backfire as bad or at all? or does it get worse? sorry to here that man. stripped threads really suck.
Old Sep 3, 2001 | 11:34 PM
Xenodrgn's Avatar
145K... and I have a feeling they were hard miles... I don't know about the timing chain... after I get back from school tomorrow I'll play with the timing a little more... I'll let you know results.
Old Sep 4, 2001 | 10:45 AM
Car: 1988 IROC-Z
LOL. Hard miles. Sounds like me. Well let me what happens with the tests.
Old Sep 9, 2001 | 05:25 PM
Xenodrgn's Avatar
All problems solved!!!
I changed out my Bosch Standard Platinums with Standard AC Delco's... gapped to .45
I bumped up the timing (advanced it... turned counter-clockwise)... pulls hard, idles smooth, no hesitation...
WOOO!!!
1992 Trans Am
May 10, 2023 07:19 PM
86White_T/A305
Aug 17, 2015 12:16 AM
johanlindgren
Aug 16, 2015 12:16 AM
flash2042
Exterior Parts Wanted
Aug 7, 2015 05:58 PM
