high oil pressure
Old Sep 13, 2001 | 04:55 PM
BizzoF4i's Avatar
high oil pressure
recently when i leave in the morning the oil pressure is high (about 60). After about 20 minutes it goes back to the normal mode. Between 10-40.
Old Sep 13, 2001 | 05:58 PM
ede's Avatar
ede
welcome to thirdgen.org, i'm not sure you have a problem, it may be related to lower morning temps and thicker oil, an inaccurate gauge, and it may actually be 60 psi when you start it. i don't think i'd worry about it, it seem pretty normal to me.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Sep 13, 2001 | 09:57 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
That is exactly what mine does......over 60psi cold and 15psi warm at idle.
Old Sep 13, 2001 | 10:03 PM
Vader's Avatar
Mine does the same thing on 15W40 synthetic. After the engine gets fully warmed, the pressure drops to about 40-45 at idle.
Later,
Vader
Justice and Freedom will Prevail
Old Sep 13, 2001 | 10:24 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
When I 1st start mine and drive it, it is 60.
When it warms up its 30 at idle and about 45-55 @2000 RPM
1988 Jet Black IROC
5.7L W/ 64000 miles
Flowmaster Exhaust
Fully Loaded
My IROC In Readers Rides
My IROC
Old Sep 14, 2001 | 05:09 PM
Yarnboy's Avatar
Yea mine is about the needle's thickness above the 60 mark in the morning. Then it goes back down to the middle or so. The the valvetrain noise and false knock begins! Grr
  • Red '88 IROC 305 TPI T-5 w/3.08
  • Accel 300+ Ignition
  • Accel 300+ Pro Sleeve Plug Wires
  • AC Delco Rapid Fire Plugs
  • Dual Friction Stage III Centerforce Clutch
  • Energy Suspension Transmission Mount
  • Flowmaster Force II 3 Chamber Cat Back Exhaust
  • Gutted Airboxes
  • Hypertech Stage II PROM
  • Hypertech Airfoil
  • Throttle Body Coolant Bypass
  • Best Maryland (40 degrees) E/T 14.686, 60' 2.205, 1/8th mile 9.461, 1/4 mile MPH 93.91
  • Best Florida (80 degrees) E/T 14.88, 60' 2.163, 1/8th mile 9.540, 1/4 mile MPH 92.74
  • Best 60' 2.163(Florida)
  • TPiS AFPR set to 42psi using Accel Fuel Pressure Gauge (Installed after Maryland run)
  • Aluminum Driveshaft (Installed after Maryland run)
I am looking to buy Edelbrock T.E.S. headers with the y-pipe. I am also looking for a 3.42 - 3.55 posi disc rear. cheesy@fred.net is my e-mail, send a letter if you can help!
Old Sep 15, 2001 | 04:54 PM
89Irocz23's Avatar
high oil pressure is better than low oil pressure
Old Sep 15, 2001 | 05:27 PM
irocbsa's Avatar
how true.
Old Sep 15, 2001 | 11:27 PM
87RS402's Avatar
I get just under 75 lbs on a cold start then, once it's warm, 50-55 at idle. I don't think I'd worry about 60 psi, just be happy it's not 6 psi.
Old Sep 16, 2001 | 08:15 AM
Changa2's Avatar
Yarnboy, what do you mean by 'False Knock'?
[This message has been edited by Changa2 (edited September 16, 2001).]
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
