Best quick mod for under $100?
Old Sep 18, 2001 | 09:40 PM
Inwo's Avatar
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
I have a totally stock 84 Z28 and ran a 16.246 1/4 last time I was out at the track a couple weeks ago. I was wondering what a quick cheap mod would be to improve my times that I could do before this Friday? I don't have access to a jack til the weekend so it would have to be something on the motor or above ground, but I was looking for something that I could do before then.
84 stock Z-28 V8 305 H.O.
1/8 10.328@66.06
1/4 16.246@80.82 phear!
Old Sep 18, 2001 | 09:58 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
There isn't too much that you can do with $100, my suggestion would be to buy a K&N, advance your timing (free) and make a homemade ram air kit ( most people use dryer hose and other pieces, doesn't cost that much), but I'm not to sure on how to do it.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Sep 18, 2001 | 10:10 PM
Inwo's Avatar
Engine: 2.0 turbo
Transmission: m5
That's kind of what I was thinking, but it was my birthday yesterday and my grandfather gave me $100, I just wanted to put it to good use ;-) I'm thinking I'm going to go with the 599-60-1450 (Jegs part #) 14 inch Open Element type.
1/8 10.328@66.06
Old Sep 18, 2001 | 10:13 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
If your engine is in stock form the best/cheapest mod is to get an open element drop base 14x3 air cleaner. Get one with a 1/2in spacer. Cost, around 30$. 50$ for a K&N filter. 15$ for the gromet set and breather cap that you will need to replace the stock breather with an aftermarket air cleaner.
SSC
Old Sep 19, 2001 | 06:20 AM
MartyMcFly's Avatar
Car: Z28
Engine: Edelbrockified 305
Transmission: 700-R4
Just do what the ricers do, a gigantic yellow "R" on the window adds 100 hp
Ludicrous Speed GO!!!
Old Sep 19, 2001 | 06:49 AM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
Spend another $10 and go back to the track and learn to drive. It took me 100+ passes in my (flamesuit on) Civic to be deadly consistant. Even the stock class bracket racer hunted me down asking me about bracket racing.
"I have a son and no time on Saturday nights for racing" is what I told him.
"Good!" he said, no need for the competetion!
The he finally realized I dated his daugther in high school.
"You should have married her"....
He runs a dead on 14.00 in his 340 dart.
And has for 12 years with only 2 refreshes.
Guess I have to win him over again!
86 T/A 5.0 A4 & 2.77 gear
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
Old Sep 19, 2001 | 09:14 AM
Inwo's Avatar
Engine: 2.0 turbo
Transmission: m5
Hehe that's the idea, but I was just looking for something to "add power" or something like that. I'm going to fool with the timing and get a K&N and hope that there's less than 200 cars there this Friday
<font face="Verdana, Arial" size="2">Originally posted by Mista:
</font>
1/8 10.328@66.06
Old Sep 19, 2001 | 10:27 AM
wataru's Avatar
this may not be the way you wanna go but you can get a pair of flowtech headers for like a $120. I know they may not be the best but hell anything is better than stock and they have the o2 bung to boot.
'89 firebird formula tpi
custom cold air,gutted maf(just screens),52mm tb,ported plenum,edelbrock runners and base,headers with 3" catback,tb coolant bypass,afpr@44 psi,msd 6a w\blasterII coil,3.73 posi,sf connectors and corvette servo
Old Sep 19, 2001 | 11:05 AM
87tpi420's Avatar
could check the for sale stuff to and migh find something usefull for your car a bit cheaper
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake hooker long tube headers mufflex 4"exhaust accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
http://people.ne.mediaone.net/gdm
Old Sep 19, 2001 | 11:43 AM
Car: 99 Formula
Axle/Gears: 342
Do those headers come with a y-pipe, cause he's going to need it.
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
160* Stat
3:73 Posi
Rebuilt 700R4
Old Sep 19, 2001 | 12:30 PM
Inwo's Avatar
Engine: 2.0 turbo
Transmission: m5
For this winter I plan on getting some JetHot coated Hooker Comp Shorties, nice and shiny they are Not going to do anything major til then, complete Hooker exhaust and an open cat. Speaking of which my current cat is most likely clogged resulting in me being out of the 15s (that and my 2.2 60' times :-() I'm placing the order from Jegs right now for the 599-60-1450 K&N Open Element Aircleaner. Now I just have to figure out what to do with the hoses that are hooked up into the Aircleaner atm. What DO I do with the hoses like that big silver one that feeds warm air or the vacuum hose that goes to the carb or the sensor? Do I just plug them off and hope for the best or does it come with an attachment for them on the open element(heh)?
<font face="Verdana, Arial" size="2">Originally posted by wataru:
</font>
1/8 10.328@66.06
Old Sep 19, 2001 | 03:14 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Whats the 8th digit of your VIN? H or G? Base don 16s at 80mph i'd say it's an H, in other words you do not have a HO.
If you do in fact have an L69 (vin G) then something is dead wrong with it. At worst an L69 will run mid-low 15s at ~90mph.
Maybe i'm crazy, but IMO there is nothing worse than modding a car that isn't in peak condition.
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
305 TPI A4 2.73 - 14.8 @ 93.1
Stock except ported plenum and dual cats
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Sep 19, 2001 | 04:35 PM
Inwo's Avatar
Engine: 2.0 turbo
Transmission: m5
Nope it's an L69, G is the correct digit, I don't know whether the motor is tired (129k miles) or if it's out of tune, HOWEVER after I came back from the track I took it to get the tranny oil changed and found the transmission mount to be broken. Now that that's fixed my car grew some perverbial ***** and seems a Lot faster. Stay tuned for an updated set of ETs
<font face="Verdana, Arial" size="2">Originally posted by Ed Maher:
</font>
1/8 10.328@66.06
Old Sep 19, 2001 | 06:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If L69, then you should have the dual snorkel air cleaner. If so, the open element is a complete waste of money and even a step backwards.
The K&N will flow more air than paper, but isn't the best for protecting the engine. AMSOIL oiled foam air cleaners flow as much as K&N, hold as much dirt as K&N, trap smaller particles than K&N, last as long as K&N, and cost about the same as K&N.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Sep 19, 2001 | 07:00 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i gotta L-69 and mines doesnt have a dual snorkel air cleaner.....i wish my car would have it
and my car hasnt had a tune up in like 3 years and i cant find the stupid timing thing so my car is probably way outta tune....but anyway.....my car runs high 15's
im hopeing that it is outta tune...so then it will b even faster!!
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
new best E.T. (dont laugh) 15.986 @84.93mph
old best E.T 15.997@86.04
http://www.geocities.com/K_towngangsta
Mods-
K&N Air filter
Twin_Turbo
Mar 14, 2016 10:10 PM
mackjar66
Sep 14, 2015 01:17 PM
Deemax
Sep 12, 2015 06:53 PM
Doobie52
Sep 11, 2015 06:19 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
