View Poll Results: which heads would you go with?
World Products Sportsman II Heads
10.00%
Dart Iron Eagle Platinum Cylinder Heads
90.00%
Voters: 10. You may not vote on this poll
between these two heads?
Old Jul 14, 2005 | 12:52 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
both 64cc chambers, 200cc runners..
priced cheap for my budget for something better then stock that can handle an lt4 cam..
which one would you choose? or think performs better out of the box with only gasket matching in mind?
Old Jul 14, 2005 | 08:21 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
In that case don't go with any world heads, they flow horrible out of the box.
I hate world heads, for the money you have much better options.
Old Jul 14, 2005 | 07:29 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
what about trick flows, edelbrock, brodix track1
they have the new vortec's with regular bolt pattern, but you need an intake with raised intake ports so guess those are out
you could get some worked aluminum(vette) L98 heads
Old Jul 14, 2005 | 10:44 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
3 words AIR FLOW RESEARCH. I would go for their 190 CC. Those will outflow the others on your list from only 190 cc intake ports. That means the more hp and more torque.
Old Jul 14, 2005 | 10:46 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
AFR=$3000.00-$8,000
Old Jul 14, 2005 | 11:19 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i chose these two cuz im not exactly rich nor am i going for top drag, i just want a peppy motor that can pull decent 12's on motor with my budget, and right now my budget is about a grand for a set of heads.
Old Jul 14, 2005 | 11:55 PM
kairles's Avatar
Engine: 383/LGX
Originally posted by Mcdamit
AFR=$3000.00-$8,000
why does their catalog say different like $1200-$1800 for the L98 angle
edit- for the 195's
Old Jul 15, 2005 | 12:13 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
AFR=$3000.00-$8,000
go back to 3go where you belong
Old Jul 15, 2005 | 06:26 AM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
200 cc intake runners are probably too large for what you have in mind. I agree on the 190 cc AFR comment, but they are very costly.
L31 Vortecs is probably the best budget choice for out-of-the-box performance, figure $750 for the heads + intake. If that's not the $$ range for you then you could buy used parts, or consider the aluminum LT1 head mod that listed as a sticky at the top of the TPI page, or port some factory stock heads (the least expensive of all choices).
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
