Stock 350 - Looking do do a few mods - any suggestions?
Old Sep 24, 2001 | 11:05 AM
88 GTA Notchback's Avatar
My car has a stock 1988 350. She has over 145,000 miles and starting to run rough and has lost some power. I'm looking to spend between 2000-3000 dollars to fix it up. Any suggestions on what to do to it? I dont just want to fix it up, I would like to increase the power of the car beyond what a stock engine will produce.
Jacob
88 GTA Notchback
A4 / 350
Stock
** New User Name**
Kill List:
95 Mustang GT |88 Mustang GT
94? Impala (real close)|97 Dodge Neon
86 Corvette |2000 Prowler
88 ASC GTA | And a few more Accords and Neon's.
And more Civic's then I can count. Why do they even bother?
Old Sep 24, 2001 | 11:29 AM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
$2000-3000?
For thatprice you could rebuild your 350. And with that much money, you wouldn't have to rebuild it with stock L98 parts (I'm assuming its an L98becaue you said 350, although that isnot necessarily true) but rather, good highperformance parts. Good pistons, rods, nice cam.... get decent heads and port and polish them. While your at it, get a set of headers in there while the motor is out (if u dont already have them) and a good exhaust. If you have TPI, I would spend theleft over money upgrading some TPI components.
In short, if you are gonna do the labor yourself, with $2000-$3000, you can do a lot!
1989 Chevrolet Camaro IROC-Z
L98 - 350c.i. TPI, rebuilt 700R4 auto w/shift kit, Dual catalyst Monza PaceSetter Cat-Back, SLP 1 5/8 Coated Headers, 3.23 Posi rear, Hypertech chip with 160stat, MSD 6A, Under-Drive pulleys, AFPR, K&N's, !Air Box w/ Ram Air, moddified MAF, !TB Coolant, Spohn Dual Cat SubFrame Connectors, Alarm, Keyless entry, remote starter, 92 Z28 AeroWing, Brand New Paint (6/21/01)
Future: ZZ4 TPI w/EGR, T56, 3.42 or 3.73, Spohn strut tower brace and LCA's
1989 Chevrolet Celebrity Eurosport
2.8 MPFI, no mods
225,000 miles and still ticking!
More info and pics on my webpage:http://go.to/iroc-z
AOL IMer: GPA 0point0
Old Sep 24, 2001 | 10:05 PM
The engine is an L98.
Unfortunatly, I wont be doing the work myself. :-( With the hours I work, it's impossible. Does anyone have suggestions on what brand/type of pistons, rods, cam, ignition system...etc..
I'd be intrested to see what vader thinks. My mechanic can do the work but you all know what works best in the L98.
Thanks!!!
Old Sep 24, 2001 | 10:21 PM
btt
Old Sep 25, 2001 | 12:34 PM
btt
Old Sep 25, 2001 | 01:58 PM
un4givin89's Avatar
I don't know, I sugest getting Chevy high Performance Ma, and Super Chevy, reading through, look for ideas, browse these forums, and do some resreach. Plan out a *** budget. Basic stuff. ... my .02 cents
Old Sep 26, 2001 | 12:25 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
dude get some performance valve spring and get the biggest high lift cam u can find well that is reasonable for ur street mods, then get some flat tops and some headers and some sweet exhaust set up. make that ground rumble and smoke those tires to high he!!
u will shake the ground and when u pull u p to car at a stop light they will definitely look cuz of the sweet sound from teh cam
Old Sep 26, 2001 | 12:33 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Why not just buy a crate engine, plus they come with warranties, at least mine did. Then again I'm not sure how well your TPI would work with it. Because by the time you pay for labor I would think you could get more out of a crate motor.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
theshackle
Mar 5, 2017 06:37 PM
camaro71633
Sep 1, 2015 10:24 AM
NinjaNife
Aug 23, 2015 11:49 AM
NWAsonoma
Aug 18, 2015 05:45 PM
sreZ28
Aug 14, 2015 07:48 PM
