clicking?
Old Sep 27, 2001 | 05:49 PM
PonyKillerZ's Avatar
clicking?
When Idling it clicks...its faint but I can still hear it.
Its been doing it for a long time. I keep the oil changed and checked..
5-w30 syn.
When I accelrate it gets faster and a little bit louder...not much.
"Only ricers do fly-bys"
Old Sep 27, 2001 | 06:12 PM
on the drivers side too...
Old Sep 27, 2001 | 06:21 PM
Yelofvr's Avatar
Probably the injectors, mine click quite noticeably, the are SVO 24lb/hr
Old Sep 27, 2001 | 06:34 PM
what does the clicking mean?
Old Sep 27, 2001 | 06:35 PM
rezinn's Avatar
Have you adjusted your valve lash? Do you have aftermarket injectors?(they can be louder than stock)
Old Sep 27, 2001 | 09:07 PM
they are stock injectors...for 85...the block isnt stock though..
whats the lash?
Old Sep 27, 2001 | 09:18 PM
rezinn's Avatar
Setting the lash is how tight you make the rocker arm adjusting nuts. Too tight will cause the valves to hang open, too loose will cause a tapping noise that gets higher with rpms.
Old Sep 27, 2001 | 10:49 PM
reletively easy to fix on my own?
Old Sep 28, 2001 | 03:33 PM
cfabe's Avatar
Setting hte valve lash is pretty simple, really. Its been posted here before, do a search. You say not a stock block. If the engine was rebuilt with solid lifters, then you may have a real hard time getting there to be no valve train noise. I bought a used 350 to put in my car, and I'm assuming its got solid lifters rather then hydraulic because I can go from lumpy idle to ticking in 1/8 of a turn on the nut.
Old Sep 28, 2001 | 04:11 PM
I am pretty sure they are solid...I can really only here the ticking while the windows are up...
and if it is the injectors...im going to wait untill I get the new runners and injectors 24# ect...cuz Ill need a new chip anyways..
RS Reaper
Oct 17, 2018 07:52 PM
Linson
Oct 1, 2015 09:50 PM
sahlomonic
Sep 20, 2015 07:15 PM
Denricci22
Sep 18, 2015 09:02 AM
