Installed 23lb Accel injectors......got problems now!
Old Sep 28, 2001 | 06:45 PM
Jeff 91Z28/L98's Avatar
I bought the injectors from Mike at cruzing performance and put them in today. 2 seconds after its running I get a SES light. It's running really rough and hestitates when given gas. It smells like it's running really rich. I first tried running it with the stock chip and then switched it out witht my performance resource chip, neither solved the problem. Should I turn the Fuel pressure down or up? It's at 48 right now. Any help out there is appreciated.
1991 G92 Auto L98 - 3.23 71,000 miles
BBK 52mm Throttle Body, Ported Plenum/Runners, Edelbrock TES Headers (JetHot coated),
Dual Cats, American Thunder 80 Series Catback,Accel Wires (8.8mm), 160 Thermostat, TPIS AFPR (48psi),K&N Air Filters.
Rebuilt 700R-4. Thanks "Transfixleo".
1st time at the track, guess I should learn to launch right.
60ft: 2.15
Qrtr: 14.20
MPH: 98.49
http://www.geocities.com/ssgtmcmichael/.html
Old Sep 28, 2001 | 07:03 PM
Guest
Guest
Posts: n/a
Did you check the codes?
Old Sep 28, 2001 | 07:05 PM
No, Not sure how to unless I take it to a garage.
Old Sep 29, 2001 | 08:31 AM
IROC&ROLL
Guest
Posts: n/a
You can display your codes by putting the computer in diagnostic mode. To do this you will need a very hitech piece of equipment... a paper clip (or anything that can jumper 2 pins on the ALDL connector under the dash). They sell a little key-like deal at AutoZone for about a $1 if you really want to get fancy. With the key off, insert your "diagnostic tool" between pins A&B on the ALDL (diagnostic) connector. These are the 2 upper righthand pins. Then turn the key to the 'on' position (don't crank it). This will put the ECM into diagnostic mode. The SES light should start to flash. It will 1st flash a code 12 indicating the ECM is in diagnostic mode. The light will flash 1 time, then a short pause, then flash twice followed by a slightly longer pause. Get it, 1 flash, 2 flashes = 12? This will repeat 3 times, then a longer pause. Then any trouble codes stored in the ECM memory will flash. Each code stored will flash 3 times, followed by a pause, then the next code will flash. After all codes have flashed, the sequence will repeat itself until the key is turned off. Have a pencil and paper ready to write doen the number of flashes.
Old Sep 29, 2001 | 09:15 AM
Great thanks iroc
Old Sep 29, 2001 | 10:50 AM
JETHROIROC's Avatar
Sounds like another victim of leaky Accel 23# injectors to me. I had two of them to wash the cylinders brand new. Is your fuel pressure holding?
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Sep 29, 2001 | 12:27 PM
Well the pressure is staying steady at 48psi and the Code I'm getting is 33.
Old Sep 29, 2001 | 12:38 PM
Code 33: High Voltage (low Vacuum) at Mass Air Flow Sensor (or Map Sensor). Ok, what next?
Old Sep 29, 2001 | 04:43 PM
Jason M 91Z's Avatar
Sounds like you got a vacuum leak. Make sure you didn't forget any vac lines, and that all the gaskets are sealing well.
-Jason M. 1991 Camaro Z28
rocn7roc
Sep 21, 2021 02:16 PM
Infested
May 22, 2018 11:56 PM
tazs2000
Jul 15, 2017 08:44 AM
Fronzizzle
Aug 17, 2015 02:52 PM
TheJoeY88
Aug 13, 2015 06:51 PM
