When good gas caps go bad...
Old Oct 2, 2001 | 01:17 PM
Bugsbunny's Avatar
Hey y'all,
Do gas caps go bad? My car started running really weak yesterday like it lost it's "umph" after a little bit of driving when it was 100degrees outside. When I stopped at a gas station to fill up, there was hella pressure in the tank, way more than ever! Now after this, it was fine as I drove home. Today the cap is loose for now just in case. Does this all sound legit? Can gas caps cause this?
Bugs
Old Oct 2, 2001 | 01:22 PM
V12Kid's Avatar
hmmmm.. weird, I have had the same thing happen once in a while, good question. Anyone have any input on this?
Old Oct 2, 2001 | 01:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Gas caps are designed to hold pressre, for emissions reasons. In fact, alot of newer cars will set a code if there isn't enough pressure built up in the tank.
I'd be more inclined to attribute the difference in driveability to the new gas you got.
ICON Motorsports
Old Oct 2, 2001 | 03:02 PM
Bugsbunny's Avatar
It's never held this much pressure before. It was really really bad. Are these caps designed to hold a certain amount of pressure and then release above a certain point? If so, thats my problem. Thats why I'm asking.
Old Oct 2, 2001 | 03:07 PM
Enkil's Avatar
The gas tanks are supposed to be pressurized to keep emissions down, as was previously stated. On hotter days, more pressure is going to build up. The increased pressure isn't going to decrease drivability any, and I would also think that the type of gas you put in might have something to do with it. (Was it crown? heh) Or, it could be related to a number of other random things. It's certainly not going to be the gas cap. If there wasn't any pressure under the cap, then I'd be concerned with replacing the cap.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Oct 2, 2001 | 05:38 PM
Bugsbunny's Avatar
Here's the thing...there was TOO MUCH pressure in the tank. Are the caps supposed to release pressure after a certain point? I don't want it to explode on me!
Old Oct 2, 2001 | 05:57 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
For all practical purposes, there is no such thing as too much pressure. It doesn't hurt anything.
Out here in CA they actually use a machine to test gas caps for their pressure-holding ability... your car will flunk if it doesn't hold pressure.
Actually, it sounds like you might have had some gas that was formulated for cooler weather in there before, and the new gas was set up for hotter weather. They vary the volatility of gasoline quite a bit to adjust to the predicted weather.
ICON Motorsports
Old Oct 2, 2001 | 06:14 PM
Bugsbunny's Avatar
Here's the only change is gas I did. I usually always use Chevron and sometimes shell. Well this weekend I was traveling and put in Union 76 gas. I had already driven half a tank of it with no problem on Sunday. Then on Monday this happened when it was hot as hell outside. As for the pressure, yes there is always some pressure, but there was so much this time that when I loosened up the cap, it flowed out for like 5 seconds and a lot too like a hairdryer blowing. You guys sure that is safe????
Old Oct 2, 2001 | 07:07 PM
Enkil's Avatar
Yes, that's safe. (Hey, at least it's not leaking gasoline out anywhere.)
Did you switch octanes, by any chance?
89 iroc-z 305 tbi
Old Oct 2, 2001 | 07:32 PM
Bugsbunny's Avatar
<font face="Verdana, Arial" size="2">
[/B]</font>
Nope
Old Oct 2, 2001 | 10:28 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
<font face="Verdana, Arial" size="2">Originally posted by Bugsbunny:
Here's the thing...there was TOO MUCH pressure in the tank. Are the caps supposed to release pressure after a certain point? I don't want it to explode on me!</font>
IIRC there is a pressure release vent mounted on/near the panhard bar.
"Question with boldness even the existence of a *** ; because, if there be one, he must more approve of the homage of reason, than that of blind-folded fear."
-Thomas Jefferson
Old Oct 3, 2001 | 01:02 AM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Red Devil:
</font>
Correct. The tank pressure valve is located above the liquid level of the tank and is supposed to seal completely in case the car inverts. Excessive pressure should be vented by this valve, but the relief setting is really quite high. The valve's main purpose is to admit air to the tank as the fuel level decreases to preven crushing the tank. It would be more likely to have the excessive pressure overcome the EVAP valves and flood the canister with vapor than to have this tank valve release pressure.
Hot days and an empty tank can create a high volume of pressurized air and fuel vapor - a nice, combustible mixture. It's really quite normal to even hear the tank "relax" a bit as the pressure is relieved. There shouldn't be more than 20 PSIG in the tank, but almost twenty gallons of air at that pressure makes for a nice breeze.
Later,
Vader
Justice and Freedom will Prevail
Adobe Acrobat Reader
Old Oct 3, 2001 | 11:29 AM
Bugsbunny's Avatar
Ok, I think the gas cap is fine. It's not happening again and that day I was really low in fuel and it was about 102deg's outside at that time (in regards to what vader said). It hasn't happened again, just coincidence I guess. Anyways, I noticed the car is bogging down when it's hot outside like above 95deg's. Just started happening 2 days ago. It feels like the hp has been cut by 30%. My first thought was the fuel filter but I don't see how it could be because it runs fine when it's cool. Any ideas?
Here are my mods:
91 Z28 305TPI 5spd
Hypertech Stage II, EB Intake & Runners, Ported Plenum, EB Headers, 3" Cat, 3" FM Catback, 1.6RR's, 3.42gears, B&M Ripper Shifter, MSD Wires/Cap/Rotor/6AL, AFPR, Air Foil, K&N's, Gutted Airbox, TB Bypass, platinum plugs, and 160deg Stat.
[This message has been edited by Bugsbunny (edited October 03, 2001).]
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
BurlyChev
Aug 16, 2015 09:08 PM
