car dies at stops
Old Aug 10, 2005 | 10:46 AM
shlyd's Avatar
Car: 1991 trans am convert
Engine: 305 tpi
Transmission: 5 speed
car dies at stops
when I push the clutch in at a light the car dies it is a 1991 trans am 305 tpi I have checked the tps and it measures right there is no check engine light and if you keep the idel raised a little it will stay running by the way I have not had it scanned yet thought I would see if anyone has had simalar problem thanks sean
Old Aug 10, 2005 | 03:07 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
Try spraying throttle body cleaner into the throttle body and around the throttle plate. A friend's 87 TPI formula did the same thing and we dowsed it good with cleaner and it took care of it.
Old Aug 11, 2005 | 03:43 AM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
I would add to the above. Yes, douse the throttle plates with cleaner, hold the open by hand and shoot cleaner n beyond them a little. Then take a rag and wrap it around your finger, holding the throttle full open with the other hand, wipe down both sides of the throttle plates and the inside of the body where the plates sit. There will be a ton of black crap from the EGR. This crap builds up and forms a ridge, you need to knock that down.
Old Aug 11, 2005 | 11:03 PM
plathegame's Avatar
Car: 1986 trans am ws6, 66 grandprix
Engine: 88 iroc 5.0 tpi
Transmission: 700 r4 built by rocky pirrone
Axle/Gears: 327
i would also do a run rite 4 step fuel system cleaning w/ the throttle body desludge
Old Aug 12, 2005 | 12:40 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Check for vacuum leaks.
Old Aug 13, 2005 | 10:27 AM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
I'd check the following:
1. Vacuum leaks
2. Change the fuel filter. It might be clogged.
3. Check the spark plugs, wires and cap.
Old Aug 18, 2005 | 10:51 PM
shlyd's Avatar
Engine: 305 tpi
I gave up took the car to a good repair shop now it has had plugs, cap, rotor, mapp sensor, 02 sensor, IAC checked cleaned adjusted, a new distributor, new ignition module,base timing set, fuel pressure checked, egr system checked, no vaccum leaks found, tested with a new ECM, then they thought it might be the prom so they ordered the correct one no improvement, checked grounds, checked ecm conectors. car runs great now until it goes into closed loop then it has a midrange miss it seems like and when driving in say 2nd gear and 3rd it surges pretty bad and sometimes still dies when I push in the clutch at a light. please someone anyone help me thanks sean.
Old Aug 19, 2005 | 04:14 PM
Car: 1989 Camaro
Sounds like an E.G.R. valve problem.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
