What is my engine worth???
Old Oct 16, 2001 | 08:23 PM
70GTO's Avatar
Car: 89 Iroc Z
Engine: Carburated 427 Smallblock
Transmission: 400 Turbo
I'm planning on pulling the 350 tpi out of my 89 Iroc and installing a carb. fed stroker engine. Its a l 98 w/ a 30 over bore, new trw pistons. The bottom end is stock and has been balanced, stock heads w/new valves and screw in rocker studs. New crane cam (pretty much stock grind), new crane roller lifters, pushrods, cloyes timing set comp cams magnum tipped rocker arms 1.52 ratio. The tpi & injectors are all stock w/ no mods. Has aHypertech afpr., thermomaster chip, fan switch, msd 6A and a blaster coil. The computer and all of its associated wiring and the 700R4 stock transmission go with the deal. The trans is a GM rebuilt. The engine has less than 200 miles since being rebuilt "yes 200 miles" and runs great.
What do you guys think I should be able to get out of this setup???
"Four on the floor, fifth in the glove compartment"
Old Oct 16, 2001 | 09:14 PM
70GTO's Avatar
Car: 89 Iroc Z
Come on Guys!! I know that you've gotta have an opinion.
Old Oct 16, 2001 | 09:23 PM
Xenodrgn's Avatar
I'll give you what's in my wallet for it...
(nothing)... No, I'm just busting your *****... 350 blocks go alot these days... Someone had a spun bearing 350 longblock that someone said they should sell it for no less than a grand... "if you can't get at least that, then you'd better off keeping it for parts" was what the guy said...
So I dunno... put an add in the paper saying "fresh 350 longblock, make offer, serioud inqiries only..." and see what you come up with... each area of the counrty you'll get different dollar amounts.. (cali will give yuo -much -less, while if you were to sell it here, you'd probably get the highest amount (parts yards are -ver- expensive around here)....)
Hope that helps you out...
1985 Camaro SC - 2.8L, auto.
C'mon, spin 'em for papa...
http://www.xenodrgn.f2s.com/Frontright.jpg
Old Oct 16, 2001 | 09:24 PM
Xenodrgn's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Xenodrgn:
[EDIT] Crap, I didn't even see that you were including a trans with the deal.. right there you should add about another 800...
</font>
Old Oct 17, 2001 | 09:43 PM
agawam's Avatar
I'm rich!! I'm rich!! I got a bunch of 350s hanging around all 4bolters and a 400 4bolter at a grand apiece I'm rich!!
Old Oct 18, 2001 | 12:23 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
<font face="Verdana, Arial" size="2">Originally posted by agawam:
I'm rich!! I'm rich!! I got a bunch of 350s hanging around all 4bolters and a 400 4bolter at a grand apiece I'm rich!!</font>
That 400 4-bolt is about as useful as a slingshot at a gunfight.........
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Oct 18, 2001 | 12:53 AM
85 Berl's Avatar
I would take it.
[This message has been edited by 85 Berl (edited October 17, 2001).]
Old Oct 18, 2001 | 05:45 AM
agawam's Avatar
The 400/4bolt just came back from the machine shop it's a 71 std bore with no cracks or flaws found it is sitting on a stand awaiting the hardblock to arrive then off to the machinist again for decking, bore job with plates,cam berings ect then home for the 377 scat assy.the scat crank has 400 size journals so no spacers
Old Oct 18, 2001 | 09:31 AM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
I'd Trade you that setup for my '83 Z28. It's a 305 auto with NO t-tops. It's a solid project/driver. I doubt you'd be interested, but if you or anyone else would be interested in trading me a tpi setup and 700R4 for this car, let me know. I need the setup to put in my '64 Chevy SWB truck
edit: See it here: http://communities.msn.com/ClemsProjects
Clem
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
[This message has been edited by clemsparks (edited October 18, 2001).]
Old Oct 18, 2001 | 01:32 PM
Ovrclck350's Avatar
1000 for a 350 longblock w/ a spun bearing? Damn. Around here 350's are like crackheads in New York, they're everywhere. I could get a new rebuilt one for $400 w/ a core...and I have 4 cores in the back yard.
Tranny's? you can get a good 700R4 for around $200 here.
Old Oct 18, 2001 | 06:19 PM
JETHROIROC's Avatar
Ovrclck, haven't seen too many "good" trannys for $200 (unless you built it yourself and add at least $100 to that for good internals, or just like charity), nor have I seen a stout 350 rebuild I would waste time slapping in my vehicle for $400. It's hard to even find a good set of heads for that price. Maybe for a beater, or for strictly bone stock (or worse) purposes, but not for building something worthwhile.
He's talking about the engine, tranny, TPI setup and harness, and computer. That should carry at least a $1500 price tag, IMO.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Oct 18, 2001 | 07:58 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
In Lafayette, a 700R4, used is about $600, a rebuilt one is $1200 from a tranny shop. I bought 2 350's, both need rebuilt, all parts there, but no on the enigne, 1 is a 98, the other a 91 $500 for both, and the 98 had the Vortec heads. 91 had spun rod brg., 98 had broken crank. I would expect to pay a good $3000-$3500 for the rebuilt 350 w/TPI and a 700R4 if I could get reciepts.
Joshua Johnston
1991 Z-28
350, T-5, K&N, Ported Vortec heads, Edelbrock RPM, Holley 750 D.P., HEI, 11.07:1 CR, Comp Cams Roller-.510"/.520"-282*/288* dur., Shorty Headers, Dual 2.5 Exhaust, Dynomax Bullet Mufflers, T&R Motorsports custom air intake, Bald tires
Old Oct 20, 2001 | 07:14 PM
70GTO's Avatar
Car: 89 Iroc Z
Clem, sorry can,t do it. I'm gonna need the cash for for the stroker engine. Thanks Josh, thats pretty much in the ballpark with what I was thinking.
Thanks all, Bruce (70GTO)
jhawkeye
May 25, 2022 06:33 PM
Streetstuff
Sep 7, 2015 09:23 AM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
355tpipickup
Aug 19, 2015 10:02 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
