Hood clearance with carb spacer
Old Sep 2, 2005 | 07:21 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Im gonna have to run a carb spacer on my car, the type that help keep the heat down. It a 91 that i converted over to carb, just wondered if i will have hood clearance problems. Oh and im running RPM intake edelbrock 1406 carb with 14 3 breather
Old Sep 2, 2005 | 07:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Check your hood clearance with a lump of plasticine and find out.
Old Sep 2, 2005 | 07:58 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
It would be really close, if i had to guess i would say not enough room, sounds like you need my spare cowl hood
Kevin
Old Sep 3, 2005 | 07:20 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
yes i do, how much u want for it?
Old Sep 3, 2005 | 07:34 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
Sorry for the off topic but since you've got the hood coming off can you take some pics of the carb conversion (all of the plumbing and stuff) and email em to me? I'd really appreciate it!
Thanks,
Mike
Old Sep 3, 2005 | 09:21 PM
Engine: 383, L69
PM sent
Old Sep 3, 2005 | 09:25 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
I can bet yours diffinitely won't fit. My street dominator is about the same height as a performer and i have a 1405 and the hood just hits the air cleaner
btw is that hood scoop still available?
Old Sep 4, 2005 | 05:55 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Ill try to get those pics to you as soon as i can. Theres not really much to it, just have to re-route a few things
What kind of spacer are you running? The one i need is i think 1/4 or 1/2 inch
Old Sep 4, 2005 | 10:03 PM
305Camaro84's Avatar
Car: 1894 Camaro Berlinetta 305 auto
Engine: 305 LG4
Transmission: TH 700 R4
i dont know about your hood but i just got an edelbrock open element filter and it bearly fits under my hood
Old Sep 4, 2005 | 10:35 PM
burntblues's Avatar
Car: 1989 Camaro RS
I really appreciate it! I can't really figure out how to route the gas lines or the vacuum lines. What size fittings do I have to use to connect up the fuel lines?
THanks again,
Mike
Old Sep 4, 2005 | 11:18 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
On my 84 im running a edelbrock 2701 intake, 1406 carb, and the 14" open element and i have inder 1/4" clearance... without some type of low pro air filter its not going to fit.
Old Sep 4, 2005 | 11:22 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Firebird hoods have less clearance than Camaro hoods.
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
kah992
Aug 19, 2015 02:55 PM
