cold starts suck!!!
Old Oct 21, 2001 | 09:07 PM
89Irocz23's Avatar
cold starts suck!!!
ok heres the deal. I go to start my car in morning and it just turns and turns over. After about turning it over for about 20 times it will start. My fuel pump primes and all that good stuff. I do have spark and everything. Once its running it runs pretty good. This is the thing though if I dont feel like letting it turn over and over I can spray starter fluid stuff in throttle body and it cranks right up.
Old Oct 21, 2001 | 09:09 PM
Enkil's Avatar
What kind of engine do you have?
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Bawls's Avatar
Car: 1985 IROC-Z
Engine: LB9
ok
No License, No Hope.
FILTERCHARGED BABY
Old Oct 21, 2001 | 09:26 PM
89Irocz23's Avatar
350 TPI freshly rebuild. It has done this ever since I have owned this car so.
Old Oct 21, 2001 | 10:07 PM
firbird's Avatar
since it starts when you put that fluid int there i could be too lean at start up, the cold start up injector might be cloged if you have one
Old Oct 21, 2001 | 10:08 PM
breathment's Avatar
replace the coolent temp sensor if u haven't already, im pretty sure thats the problem.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
[This message has been edited by breathment (edited October 21, 2001).]
Old Oct 21, 2001 | 10:18 PM
89Irocz23's Avatar
is that the sensor thats in front of the manifold? Cause if it is then I changed that. When I was changing it like a week ago I got water all over the connector< i dunno if that matter or not, but just thought I would let u know.
Old Oct 21, 2001 | 10:41 PM
firbird's Avatar
yea thats it, should not matter as long as it still dont have water sealed in the connector, and yea i need some sleep and i dont know why i am still awake :P
Old Oct 21, 2001 | 11:58 PM
breathment's Avatar
89+ don't have a cold start injector, and im guess thats what he has, because of his user name, but if its 88, 87 then u will have one. does anyone know if there is a relay or anythign for main injector enrichment for 89+ TPI's?
- David
88' GTA 5.7L TPI MODS---&gt; air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
Old Oct 22, 2001 | 02:55 PM
89Irocz23's Avatar
yeah I have the 89. There is no cold start injector. I know I have replaced maf, maf relay, and burn off relay. Still dont know why its hard to start.
Old Oct 22, 2001 | 03:00 PM
89Irocz23's Avatar
heyr Vadar I know your real experienced at this kind of stuff. Any ideas?
Old Oct 22, 2001 | 06:47 PM
89Irocz23's Avatar
btt
Old Oct 22, 2001 | 07:06 PM
breathment's Avatar
did u replace the Air Idle Control Vavle?
- David
Old Oct 22, 2001 | 07:36 PM
Desert86Roc's Avatar
What is your fuel pressure set at? Also...check for vacuum leaks. Do you have a stock, or custom eprom?
Mike Metzler (Desert86Roc)[*] Check Out:SpeedWorldMotorplex.com[*] Check Out:Chevrolet F-Body Online Part & Illustration Manual[*] My 86 IROC 305 TPI Page (406 build in progress)
ET's @ 1250 ft[*] 14.28 @ 95.461 mph (uncorrected, NOS, no headers)[*] 15.362 @ 88.238 mph (uncorrected, headers, no NOS)
&lt;&gt;&lt;
Old Oct 22, 2001 | 08:02 PM
89Irocz23's Avatar
no I havent raplaced my IAC yet but it idles ok I guess. Im not sure about fuel pressure dont have a guage yet. Dont really have the money for one yet. For chip I think its the stock one, almost positive. I dunno who makes chips for tpis or anything or dont have the extra couple hundred for one so.
Old Oct 22, 2001 | 08:49 PM
michael's Avatar
Car: 1991 Formula
Engine: 6.2 383 TPIS Miniram
Axle/Gears: Moser 9" 4.11
I'm having the same problem. But its a 87 2.8 mpfi ho. Is that temp sensor the one that controls the gauge? Cause my temp gauge don't work but if I have the dash apart I can move the needle down and start the car and it pegs and sticks but if i knock it back down while still running it sits at like well 150-160 I suppose, then I shut off and restart and same thing it pegs and sticks. Is there supposed to be a needle stoping it? My car is pulling the usual code 34 which leads to the maf but I do the tap while running and it wont stutter.
1987 Chevrolet Camaro
2.8 Ltr HO Cut air boxes K&N Filters Gutted Cat (Did I say gutted opps don't tell the officer)
Duel catback Exhaust With Flowmaster series 80 dual 5"X24" MONSTER Echos
97 Firebird 16X8" Rims
Old Oct 23, 2001 | 02:54 PM
89Irocz23's Avatar
for youyr temp guage the sensor is on the drivers side head. There is also a sensor that goes into the manifold for the temp of the water, but thats for the computer not the guage, If it pegs the wire for the sensor may be off of it and grounding on something else. Happen to me once.
Old Oct 23, 2001 | 10:22 PM
89Irocz23's Avatar
btt
Old Oct 25, 2001 | 02:57 PM
89Irocz23's Avatar
come on someone you gotta have some info for me
Old Oct 25, 2001 | 09:49 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Just my guess...but you say it starts when you use starting fluid? Should indicate you're not getting fuel.
When the engine is cranking over, and she fires off, does it run smoothly? If so, I'd be wondering if the fuel pump is priming the rails when you turn the key on, because it seems to me that what's occurring is as you're cranking the engine over, the oil pressure switch is getting pressure, after 15-20 cranks there's sufficient pressure to close the switch and send the voltage to the pump.
If this is the case, the possible causes could be the FP relay, the wiring, or the ECM.
Best way to start diagnosing would be to use a FP gauge and a DMM.
Old Oct 26, 2001 | 10:28 PM
89Irocz23's Avatar
yeah I am gonna invest in a fp guage soon so i can test it. Once its running it runs smoothly so I dunno. Could it be the relay even if it runs smoothly when it gets started. Its like after it sits for more than 6 or 7 hours it takes forever to start. I know the fuel pump primes, but maybe its not getting to the rail.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
